Home Forums Sign Making Discussions General Sign Topics Mactac RGB values
  • Mactac RGB values
    Posted by image on 6 November 2003 at 11:17
    Hi!
    Anyone have the RGB values for simulating Mactac vinyl colors?
    (Macmark 9800, 8900, 8300 series).
    I would like create a Mactac CorelDraw color palette. ๐Ÿ˜‰
    Thanks!
    image replied 22 years, 1 month ago 8 Members · 13 Replies
  • 13 Replies
  • Tim Shaw
    6 November 2003 at 11:33
    Have you tried scanning in the Mactac colour swatch card,
    Adjust the brightness, contrast of the scan till it looks ok on screen.
    Then you use the color pick up / eyedropper tool to select each colour and make up the pallete to be saved.
  • image
    6 November 2003 at 13:00
    Tim,
    scanning is good idea, but my scanner is not calibrated correctly.
    If it’s possible, I want make an “official” Mactac palette (e.g. with original RGB-values from Mactac). ๐Ÿ˜‰
    I tryed match Mactac colour swatch card to RGB values with my Pantone colour reference guide, but the result isn’t perfect.
  • Steve Broughton
    6 November 2003 at 13:25
    They are there in Signlab if you use it Barna.
  • Rodney Gold
    6 November 2003 at 13:48
    Why would you want to do that ? have you colour calibrated the monitor to simulate the vinyl or color calibrated the the printer? If you haven’t it’s a waste of time unless you print it – even if you print it RGB does not translate 100% to cmyk at all and even if you HAVE colour calibrated your monitor – the only thing you can do is show customers on YOUR Screen – theirs won’t display correctly if you send em a pic unless they have calibrated theirs with respect to ambient light etc.
    My rep will give me as many brochures and colour swatches as I want – much easier to show that to the customer then try simulate vinyl colours on screen.
  • image
    6 November 2003 at 15:04
    I haven’t got Signlab. Can you export this palettes or RGB values?
    Rodney
    Not for proofing! If I have a Mactac-Corel palette, and I open a document some years later, I can see which vinyls we used. Certainly it helps me to work/design faster.
    Unfortunately, I am a maximalist, therefore I would like make a good palette. ๐Ÿ˜‰
  • Adrian Howard
    6 November 2003 at 15:27
    in signlab the file ending is .pal can these go into corel if
    so i can email them to you
  • Rodney Gold
    6 November 2003 at 16:13
    Ah ok , I understand – thought you were doing colour proofing for clients etc. does your sign program have a data base attached ? What we do is enter the invoice with full descriptions in our accounts program and have a file for each job attached to the job (signlab) with extensive descriptions of colours , materials , pricing etc cos a lot of jobs we normally store as outlines without fills and so forth.
  • image
    7 November 2003 at 12:16
    Adrian,
    please send me via e-mail these Mactac *.pal files. I downloaded the Signlab demo, therefore I sure can use these palettes.
    Many thanks!
    Rodney,
    we use CorelDraw for sign design, I suppose so it not supports databases, but your technology gives me many ideas.
    Thanks!
  • sammyr
    7 November 2003 at 20:30
    just keep a hard copy of what you produce & write your vinyl codes on !
  • Alan
    7 November 2003 at 23:56
    Hi Barna
    This is a Mac 9800 palette for Corel.
    http://www.aesigns.co.uk/other/MacTac%209800.cpl
    As Rodney says, you canโ€™t trust the colours on screen or in print, but the names and numbers are OK.
    Alan
    ps. you do know that you can get the palettes for Oracal vinyls if they are any good?
    http://www.oracal.com/learning_support/palettes.jsp
  • Lorraine Buchan
    8 November 2003 at 13:28
    Hey Alan that Oracal site makes interesting reading, cheers
  • image
    8 November 2003 at 14:38
    Thanks Alan!
    Unfortunately the Signlab palette does not include all colors ๐Ÿ˜ฎ
    but I’m working on it.
  • image
    15 November 2003 at 09:21
    Hi All
    I tried some way and it seems to me, the best way is the colour swatch card scanning. The winner is Tim!
    Thanks!
