Home Forums Software Discussions General Software Topics MAC TO PC SOFTWARE
  • MAC TO PC SOFTWARE
    Posted by George Elsmore on 26 May 2005 at 08:52
    I have a customer who has mac i have pc he has overcome one problem by saving the files he wants printing as pdf but another hi res file 250meg he is having trouble saving as pdf he uses illustrator8 for mac i use illustrator CS is there a way he can save something that my pc or is there converting software that i can buy? Any help would be great on this issue.
    thanks in advance
    George
    Aitor Asencor replied 20 years, 7 months ago 8 Members · 8 Replies
  • 8 Replies
  • Phil Kneale – Graphtec
    26 May 2005 at 09:31
    On his Mac, he can format a disk as a PC disk. If he does that then saves his illustrator file as normal you should have no problem.
    One small thing, Mac does not use extension, tell your customer to make sure that when he saves his file he calls it something.ai
    26 May 2005 at 22:16
    never knew that phil, thank you…
    i purchase mac opener from conversions plus, you can buy online and download. dont have web add but ide just google it 😉
  • Andrew Boyle
    26 May 2005 at 22:29
    saving the file as an eps [.eps] in ill 8 ensuring all fonts are outlined and any placed images converted to CMYK should be fine as well……a final select all convert to CMYK seem to help [gets rid of spot colours – if digital?] if re-sizing outline strokes…..
    Andrew
    not sure if it’s all correct, however if I save in ill 9 I tend to do all these things for PC
  • Chris Hooper
    27 May 2005 at 06:28
    May be of interest to the Mac/PC platform debate – we use conversions plus a fair bit
    See:: Web:http://www.dataviz.com
    MacOpener:
  • chorley signs
    27 May 2005 at 07:13
    We use a program called TransMac that will convert PC to Mac, Mac to PC and anything in-between
    http://www.asy.com/
    Hope that helps
    Rob
  • George Elsmore
    27 May 2005 at 07:38
    Thanks all for all input……you learn something new every day
    27 May 2005 at 12:50
    Use Transmac here as well, Crossfont from the same people is worth downloading too.
    Alan
  • Aitor Asencor
    29 May 2005 at 09:03
    You can exchange Illustrator, freehand, pdf, tiff, jpeg or other app archives with no problem.
    In mac record the CD as a mac/pc hybrid.
    In pc as pc is ok. Mac read pc disks.
    In both cases don’t use multissesions. You can get in trouble.
    Fonts can change from mac<>pc, so you can trace the archive first.
    Or add a paper copy to check all is ok.
    Aitor
