Home Forums Vinyl Cutter Discussions General Cutter topics MAC’s and Sign’s
  • MAC’s and Sign’s
    Posted by Dan Butler on 19 January 2004 at 18:51
    Hi All,
    Can anyone advise…
    I’ve just bought a Roland CX-24. I run a PC and a MAC, but I love the MAC and don’t want to resort to using the PC for Cutting.
    All my vector design is done in Illustrator and ideally I would like to cut straight from here, but…
    I’m running MAC OS X
    Anyone found a good solution – I don’t mind if I can’t cut straight from Illustrator – but don’t want to have to run in Classic mode
    Thanks All
    Freddy.Tait replied 21 years, 9 months ago 7 Members · 16 Replies
  • 16 Replies
  • Lorraine Buchan
    19 January 2004 at 21:31
    Hi Dan,
    Welcome to the site, I think as your a Illustrator user this could be the ideal thing for you: http://www.magisign.com/
  • John Childs
    19 January 2004 at 22:35
    Dan,
    Rather than use you main Mac you might consider getting another one purely to drive your cutter. It doesn’t have to be expensive because cutting is such a simple job that practically any old Mac less than about ten years old will be more than adequate, and available at very low cost. So little processing power is required that I could probably wire my fridge up to do it.
    You can then run this on OS7, 8 or 9 and use Cutline (www.illom.se) to drive your cutter leaving your main Mac free to use OSX for the clever stuff. Connecting the two Macs would be simple and cheap, needing only an ethernet crossover cable.
    I am using this setup with one design computer, a G4DP running OS10.3 connected to two cutting stations using the original iMacs on OS9.[/i]
  • Dan Butler
    20 January 2004 at 08:49
    Thanks All
    MagiSign certainly does sound like the thing but at the moment I can’t get the demo to work…
    I would say however that the technical guys at MagiSign have been most helpful and are keen to get it working. I’d recomend them for their customer support. High praise for a product that I can’t get to work!
    Thanks again,
    Dan
    20 January 2004 at 20:00
    downloaded the cutline as john suggested, but i could not get it to open on my mac 😳 i actually downloaded the file from a pc! would this have made a difference? oh and the mac ops is 9.1 if that helps!!
    any suggestions from all the mac users? 😆 😆
    thanks Nik
  • Aitor Asencor
    21 January 2004 at 17:38
    You can’t d/l Cutline demo from their site as it’s not available as a demo program, only a quicktime demo.
    21 January 2004 at 20:06
    thanks aitor
    macs chew my head up sometimes!!
    Nik
  • John Childs
    22 January 2004 at 09:27
    I’m the opposite nik. I can handle pretty much anything on a Mac but the only PC I own, which was forced on me to be able to get satellite broadband, gives me endless bother. I dare not switch it off in case I can’t get it running again. 😀
    Back to Cutline…
    The beauty of it is that it is simple to operate. This doesn’t matter so much if you are the only operator but if you try to train employees, some of whom may not be the brightest things to crawl out of the sea, you will get them working much quicker and have much less material wastage with an easy programme.
    Also, as a stand-alone programme you do not need a copy of Illustrator on every machine, just the ones you design on.
    Also, running like I do, the system is scaleable. If I need a new cutting station I just get a cheap Mac, install Cutline, plug it into the network and cutter and away we go.
  • Mike Antrum
    22 January 2004 at 17:35
    I’d consider Flexi-Cut.
    It only costs £ 199.00 + VAT and is the entry level for the flexi-sign range. As such you can upgrade to bigger and better versions in the future if you need to.
    Not available for OSX at the moment though 😥
    Happy Cutting
    Mike
  • John Childs
    22 January 2004 at 20:01
    Mike….
    I tried FlexiCut. Much too fiddly. It lasted a week before it went back into its box. 🙁
    22 January 2004 at 20:37
    thanks john for your reply, i have the cutline floppy ready to try out tomorrow, just had another thought, my pc runs signlab and uses the parallel port to cut, would it be possible to run the mac but use the serial port? so both are ready to cut (not at the same time) to save changing cables? hope that made sense!!
    Nik
  • Dan Butler
    29 January 2004 at 19:04
    The MagiSign demo now works – download it and have a look for yourselves. Any troubles send an email to the support team – they are second to none!
    Happy Cutting
    Dan
  • John Childs
    29 January 2004 at 21:20
    Nik,
    I think you are asking whether you can have both your pc connected via parallel and your mac connected via serial at the same time.
    Sorry, but I don’t know. It may be that there is some form of input sensing and that one will disable the other. If it would be advantageous to you I’d ring the cutter manufacturer and ask them. I would hesitate to recommend it but if they can’t give a definitive answer I would be inclined to plug it in and try it.
    Best of luck.
    29 January 2004 at 22:27
    yes i thought so too john! i will try it and see what happens, phoned roland
    but got nowhere.
    thanks anyway will keep on trying 😛 😛
    Nik
  • Mike Antrum
    30 January 2004 at 20:57
    Hi Nik,
    When you turn on a Roland cutter it senses which port is connected and disables the other. If both are connected it will pick one and disable the other (can’t remeber if serial or parallel gets the priority !) However, there is a work around:
    There are 2 ways you can do this
    1) You could get a cheap serial switch box and wire them both up via serial, and all you would need to do is flick between them (unless you got an auto sensing switch box, in which case you need do nothing).
    or
    2) Roland plotters have a setting in their menus called I/O. It has 3 options: Serial Parallel & Auto. If you set it to auto, the machine will sense which one to use, and disable the other port. But if you select Parallel or Serial, you can pick which one to use.
    Hope this helps,
    Mike
  • Freddy.Tait
    12 March 2004 at 15:22
    sorry correcting url
    http://www.typestyler.com
    click on tutorial list
  • Freddy.Tait
    12 March 2004 at 15:23
    hi list users
    i wonder if any of the list has tried typestyler software
    it has a multitude of uses for grapics signs etc
    export in illustrator , jpeg , pict, etc etc
    its worth a look
    all the best freddy at e.c.p.
    (also coming soon for OSX so it says)
    on the first page click on tutorial its a PDF
