Home Forums Printing Discussions Roland Printers Loud Brrrr’ing noise from carriage
  • Loud Brrrr’ing noise from carriage
    Posted by Chris Moore on 8 July 2019 at 10:36
    So, about a few months ago I had new scan and feed motors installed (by an engineer) on my Roland SP-540V printer.
    At first it was all really good and made the printer quite quiet in comparison to how it was before. But suddenly, it stared to make a [grinding / brrr’ing] when printing on higher speeds. I switched off the printer and restarted it, and this seemed to fix the problem. It happened again a few times when printing on a higher speed, and I just restarted it each time (about 3 or 4 times). When printing on my normal speed of 650, it has been totally fine, until today.
    It has started to make a very loud humming / grinding / brrr’ing noise on any speed. My usual on/off trick hasn’t worked and the noise is now also there when i perform a sheet cut.
    I can tell where the noise is coming from, but it is concerning me and i don’t want to continue printing if its going to cause more damage.
    Has anyone else had this at all?
    Kevin Mahoney replied 6 years, 5 months ago 2 Members · 5 Replies
  • Kevin Mahoney
    8 July 2019 at 10:57
    Sounds like the bearings are bone dry Chris, have you oiled the carriage at all?
  • Chris Moore
    8 July 2019 at 11:30
    Hi Kevin,
    I haven’t oiled anything to be honest, I didn’t know I had to? How do I do that?
  • Kevin Mahoney
    8 July 2019 at 11:40
    On the to of the carriage where the heads run you will find a groove. With the power out & the heads released, clear out any dust or debris that may have accumulated in there with a tissue & some ipa.
    Then drop in 4 or 5 drops of 3 in 1 oil into the groove & work the head backwards & forwards until its oiled the whole carriage. Hopefully the bearings are just dry & not shot, they are quite pricey if I remember correctly.
  • Chris Moore
    8 July 2019 at 12:38
    Thanks Kevin,
    I’ve just done everything you said so let’s see! It does sound better already to be honest!
  • Kevin Mahoney
    8 July 2019 at 12:47
    A bit more oil then Chris, not to the point where it’s dropping onto the media but it won’t do it any harm
