Home Forums Sign Making Discussions Off Topic Chat lorry curtains
  • lorry curtains
    Posted by davebrittain on 25 July 2004 at 16:32
    can i use ordanary vinyl which i use for cars on a curtain sider or is there a more specific vinyl any special metherd the curtain in question is quiet wrinkled
    davebrittain replied 21 years, 5 months ago 6 Members · 10 Replies
  • 10 Replies
  • Mike Rogers
    25 July 2004 at 17:51
    I would think banner vinyl which will stretch with the curtain. Normal vinyl does not stretch and will crease or crack. Banner vinyl is also slightly more adhesive than standard
    Unless anyone else knows of a specific material for curtains
    Mike
  • davebrittain
    25 July 2004 at 19:06
    thanks ille try it
  • Ian Higgins
    25 July 2004 at 21:40
    Do not use banner vinyl either.. it is not up to the job. You need to use proper truck curtain vinyl which some of the larger suppliers have… mind you it is not cheap
  • Lee Harris
    25 July 2004 at 21:42
    You would need to use ‘Truck’ vinyl. Avery do a range. I think its the 9200 range, also APA (UK) Ltd from Kent – 0208 311 4400 do a range. Cost Avery about £7.50 per m @ 610mm wide APA £4.50 per m also @ 610mm wide.
    I hope you find this a help.
    Lee
    26 July 2004 at 00:09
    here is a post on truck vinyl. maybe a interesting read for you.
    basicaly banner vinyl is for banners, steer well away from truck curtains, if using this vinyl. same goes for regular vinyl on banners. 😉
    http://www.uksignboards.com/viewtopic.php?p=10322
  • Lee Harris
    26 July 2004 at 10:43
    Hi Dave
    Wrong info. The Avery truck vinyl is the ‘Avery SignFlex 2200’ Comes in about 20 colours.
    Lee
  • davebrittain
    26 July 2004 at 12:21
    any one got a number for truck vinyl supplier i need it tomorrow as it needs fitting wednessday
  • Lee Harris
    26 July 2004 at 12:43
    Hi David
    Try APA (UK) Ltd from Kent – 0208 311 4400
    Cox Plastics – West Midlands – 0121 3275050
    Hope these help.
    Lee
  • Lanza
    28 July 2004 at 17:48
    Hi Dave.
    There are 2 types of masking film i’ve use first is MACmask by MACTAC reference 84-817 and the other which we at present use is Eco mask made by Ritrama,I prefer the former.
    Also we use banner screen printing ink for curtain siders applied with a spong carfully working away from the edges. Hope this is of some help
    Cheer Tony Lanza
  • davebrittain
    28 July 2004 at 18:02
    thanks ille put the job on show us your stuff thursday night
