• Loose panels
    Posted by Warren Beard on 14 November 2007 at 14:57
    Hi All
    I have just been quoted a price for a ready cut panatrim frame and told it is for 5-6mm thick boards but I can use 3mm dibond but it will be loose inside and therefore knock around slightly 😕 😮
    Is this normal practice or is there something I’m missing 😕
    Warren
    (sorry John)
    John Harding replied 18 years, 1 month ago 6 Members · 6 Replies
  • Kevin Flowers
    14 November 2007 at 15:02
    Warren
    you can get a Panatrim frame for 3mm but you don’t normally use a hanging strip. It also has a small face side try Novatrim 0117 9556463 ask for Gary,
    (mod-edit)
  • Glenn Sharp
    14 November 2007 at 15:10
    Warren….I don’t know the size of this sign but it probably wouldn’t harm, sticking some 1" to 2" wide vertical stiffeners down the full height of your di-bond panels.
    This would strengthen the sign up a bit but also bulk out the thickness to 6mm to stop it rattling around so much
  • Warren Beard
    14 November 2007 at 15:33
    Thanks guys
    I suppose I could pack it up at the back with strips of dibond to make 6mm, I just thought it was strange they said it is common practice 😕
    Warren
    size is 2400mm X 610mm
  • Nick Monir
    14 November 2007 at 16:35
    I use dibond in a 5/6mm frame quite often and just brace the back of the panel as Glenn suggested – never had any problems. Wouldn’t be as keen to leave it rattling about though 😕
  • David Glen
    14 November 2007 at 17:03
    Insight do the Spectra dibond frame.
    It’s lovely stuff but soooo expensive I can’t believe they actually sell any.
    http://www.insightsignsystems.com/spect … dframe.htm
  • John Harding
    14 November 2007 at 19:34
    quote :
    ive bought two in the past, great product pants packing for transportation hence both deliveries were backed be carefull to check if you buy 😕
