Home › Forums › Sign Making Discussions › General Sign Topics › looking for new cutting benches advice and recommendations
Posted by Shawn Bentley on 26 May 2017 at 22:36hi guys looking for a couple of new cutting benches, any advice or recommendations of where to buy them, also is there a recommended height for them so not to be bending over, also whats best for tops cutting matt or glass?, any advice would be helpful, tia. cheers
Shawn Bentley replied 8 years, 7 months ago 6 Members · 12 Replies -
1000mm height suits me perfectly for my 5’11".
10mm toughened glass for the top cant be beaten. It is smooth and easy to clean.
You can cut directly on the glass using stainless steel blades which dont scratch glass.
I made my table out of secondhand scaffold boards which they sell at a pound per foot. -
Cheers Simon are there any places that sell the actual tables ? Or maybe adjustable height ?
Cheers colin seen those but thank u just wondered if anything else out there etc
We have the signgeer benches as well all on wheels, we have 8 x 4 mdf tops topped off with 3mm foamex and can push together to make 10m long bench we like them
Thanks colin how sturdy are the wheels and are the benches a fixed height ? Thanks again
Hi yes fixed height but quite comfortable will measure Tuesday if you want wheels are relatively small but do the job we find them sturdy and flat and were give them some abuse sometimes including standing on them to change light bulbs etc foe the money they are quite good
That may be way to go Andrew, hoping there may be some on guys here that may buy the wooden benches in ready made but may have to go down route of having made bespoke, cheers
I would certainly consider the building route.
we have a rollsroller table but thats strictly for application and working on laying things up, weeding etcyou need to consider what you will be using it for daily.
if its an all round work bench table then you shouldnt take the glass top or fragile top route. one drop of a hammer, clunk of a sign etc and there goes your glass top.we build our benches ourselves to exactly what we need. as has been posted, strong casters with foot lock brakes bought from the likes of screw-fix are great and not expensive, nakes easy moving as and when needed. you dont think much about moving them but you do need to clean up and sweep under, so even just for this its worth it. measure the area they have to sit and make to suit that size exactly. have storage under the bench build to suit. a nice thick top with a rubber self healing cutting mat and your done. mounters mate do cutting matts, speak to Omar for a good deal. https://www.mountersmate.co.uk/
a good joiner will come in and knock up a bench for you in no time at all and i bet much cheaper than buying a steel one with limited use other than a table, sizes etc
i would sketch up ideas of what your after, what is needed on it etc and get a joiner in to do it. buy the wood and casters etc all in and your just paying for construction.just my thoughts on it anyway.
Hi rob sounds like a plan that was my initial thoughts think will give me a longer life and more multi use,
