Home Forums Printing Discussions General Printing Topics Looking for a rigid printable substrate upto 1.5mm thick
  • Looking for a rigid printable substrate upto 1.5mm thick
    Posted by antevo on 6 November 2003 at 09:21
    As the title says, I am looking for a rigid material which I can print on using Epson Ultrachrome inks, that be be used outdoors, only short terms is needed (1-3 months), but am willing to seal with frogjuice etc.
    The maximum thickness should be 1.5mm as it will go through the Epson 9600 printer.
    I currently use adhesive vinyl and then stick it onto 3mm correx, but if I could cut out this process it would save me a lot of time and effort.
    Any ideas?????
    sammyr replied 22 years, 1 month ago 4 Members · 4 Replies
  • Rodney Gold
    6 November 2003 at 11:08
    If you are using a solvent ink (IE if you are not using specially coated vinyl to print on) then you can use Styrene or ABS. Here in South africa , it can be obtained from 0.4mm to 5mm thick – Im sure the same holds there. I print on both with my Roland Soljet and you dont need to coat either if its not being scratched or handles , will easily last 3 months.
  • Lorraine Buchan
    6 November 2003 at 12:41
    I don’t know if it’s suitable for what you require but… foam PVC comes in 1mm
  • antevo
    6 November 2003 at 17:41
    quote Rodney Gold:
    Thanks Rodney, I will order some samples and give it a try.
    quote lorraine:
    Lorraine, sorry, i have tried that in 1mm just a bit too flimsy, need it a little more rigid
  • sammyr
    7 November 2003 at 20:57
    got the same printer, its pigmented ink, you need a coated substrate for the ink to ‘go into’, you can only stay with your same process.
    if you want card, them try AIT & ask for Anthony, he will source it for you….great company.
