Home Forums Sign Making Discussions Job Pricing Looking for a price quide
  • Looking for a price quide
    Posted by Stephen Henderson on 9 February 2011 at 19:05
    Hello Folks
    I have done a few vans with chapter 8 kits on the full rear (transit) a couple of them were mid roof and one low roof. I also had to add oralite reflective bands to each side (200mm) full lenth, two logos and two addresses in normal 651.
    I have more of these to do from transit connects to high roof jumbo’s, the question is !! how much should I charge, the kits are costing me from 330 for a low roof, to 410 for a high/mid roof, what should I mark them up at, then there is the oralite aint cheap either. The fitting of the kit takes me just under 2 hours then the rest of the work so around 4 hours total, could one of you fellow members point me in the right direction ?
    I did charge 560 for doing a chapter 8 on a mid roof with the oralite bands on either side, am I too cheap or in the correct playing field
    Should mention I did have to remove the old kit from this van,,well from the middle of the doors up.
    Stephen Henderson replied 14 years, 10 months ago 4 Members · 5 Replies
  • Kevin Flowers
    9 February 2011 at 19:48
    Stephen
    what you are paying for kits sound a bit on the expensive side, who are you using
  • Stephen Henderson
    9 February 2011 at 21:16
    Victory, I thought they were a bit on the dear side
    9 February 2011 at 21:20
    you should be paying no more than £200 for a full chapter 8, high roof transit(full coverage)
    try bluelite or william smith
  • Neil Davey
    9 February 2011 at 23:33
    I think you need to look at this.
    I’m not going to say your being ripped off but…….
    http://www.tennantsuk.com/chevron-kit/c … e-list.pdf
    Spandex are also supplying Chapter 8 kits so maybe worth a call.
    £330 to £410 per kit, that is too expensive and if your only charging £560 to supply and fit, and removing old vinyl too!!!!!! 😕
  • Stephen Henderson
    10 February 2011 at 09:05
    Thanks for that peter, will look into these two for prices and compare.
    Neil, good show mate, I will be looking at these also, and calling victory to see if they were charging me "jo-public" prices or trade, just so I can give them an earful
    Thanks guys
