• Long Strip
    Posted by LeeMorris on 8 December 2007 at 17:23
    I have a half inch strip of vinyl to add to a dibond panel sign its 5.6m long, is there any tip i can use to stop it running off line.
    there are 2 strips going each side of lettering so its got to run level or it will stand out.
    Lee
    Glenn Sharp replied 18 years ago 6 Members · 6 Replies
  • James Martin
    8 December 2007 at 17:27
    Masking tape it straight first and then run the vinyl along the side of the tape
  • LeeMorris
    8 December 2007 at 17:32
    would you apply vinyl without application tape?
    Lee
    8 December 2007 at 21:41
    hi
    as long as you get the start and finish correct put a slight bow in the board, attach both ends of the tape, flatten the board.
    normally works.
    8 December 2007 at 22:02
    quote Chris Wool:
    hi
    normally works.
    by gum, a good tip is that !!!
    8 December 2007 at 22:24
    quote leemorris:
    yes i do it all the time…specially on small strips, as long as you dont pull the vinyl, and make sure the length of vinyl is bigger than size you need 😀
  • Glenn Sharp
    8 December 2007 at 22:28
    It might be a bit wastefull on vinyl…depending on on the size of the text in between…………..but I would be tempted to put registration blocks on the top strip & follow those blocks on the bottom strip
