Home › Forums › Sign Making Discussions › General Sign Topics › logos in word documents
Posted by Derek Heron on 16 July 2011 at 10:23hi all
been sent a word document with the companies logo which i have to print for monday if possible 👿
i asked for a.i eps and its just a word document is there any way to get this into signlab to print decent quality
or should i have the this sunday offDerek
David-Foster- replied 14 years, 3 months ago 10 Members · 15 Replies -
You should be able to copy and paste the logo from Word into Signlab. (Failing that it will definitely copy and paste into Corel – then export)
Hi phil
it will copy and paste into my signlab and corel but pixelates badlyDerek
Hi Derek,
The word pics resolution is probably 72ppi… at very small sizes.
That’s definitely not enough to interpolate and as such are worthless for anything apart from word docs and profile gifs maybe 🙁
What logos are they, maybe we can find them elsewhere?Robert
Hi robert
its an old customer who has just went on his own so will give him a call monday for better imagethanks for the explanation
derek
Derek, it depends whether the placed image was a vector or bitmap originally)
If it looks like a vector (typical Corel type wmf) don’t just copy the image, do this;Double click the image (corner angles will appear instead of nubs).
Zoom in close and marquee select all the elements.
Right click & select copy.
In Signlab select paste & click on screen.This works using SL7- SL9 (maybe earlier) and Word 2007.
Of course the rule is NEVER accept any Word doc as artwork. -
No problem. Depending on the software you are viewing those in you can see the resolution and size when you go to image properties. I would imagine that min of 150ppi at full size or 300ppi half size is needed for print? At least that’s how I always prepare my print files?
If you blow up to real size and it looks bad that is what you’ll get- a step easily missed while working on computer, as things scaled down don’t look true.Robert
You can always get an ideal of how bitmaps will look if they are 72 dpi (screen resolution) which is probably what this will be as most programmes like that create at that resolution, by zooming in and making it the same physical size on screen that it will be. This will give you an ideal as to what it will print like. For print we insist on 100dpi at actual size.
I normally aim for 100 – 150 dpi finished size. I will quit often redraw simple stuff so I have more control over colour and resolution is not an issue any more for photos or logos not practical to redraw I use Photozoom V4 (upgrade from free V2 that comes with X5)
Alan D -
I find printing to pdf, then dropping it into signlab is a good way of doing it.
but if the image is poor to start with it doesnt improve thingsPeter
Peter do you use Signlab’s ‘Super sizing’ or whatever its called? does it work for you?
Alan D -
Hi Derek best way to get something out of word, save file as a docx if it is not already, change the file extension to .zip you will get access to the original placed files. cant remember the folder name off the top of my head – res or something, hope this helps
great if you need to get the original pic the customer has not skewed or stretched
Barry
quote Barry Dok:Hi Derek best way to get something out of word, save file as a docx if it is not already, change the file extension to .zip you will get access to the original placed files. cant remember the folder name off the top of my head – res or something, hope this helps
Barry
Top tip! Thanks!
Can you post it Derek then everyone can have a go at extracting the file and we can see which one does work best on this occasion
good morning all
attached hopefully couldnt attach the word document but managed to save to pdf and also attached high res image requested from customer 🙄derek
