Home Forums Vinyl Cutter Discussions PCUT Vinyl Cutters Loading the drivers for the Pcut CT1200 serial plotter
  • Loading the drivers for the Pcut CT1200 serial plotter
    Posted by Malcolm Cane on 8 September 2012 at 21:39
    Can anyone help i have just purchaced a Pcut CT1200 from ebay and i am haveing difficulty loading the drivers on my computer i am running XP. I have tried to follow the instruction for loading the drivers but i cannot understand them. The instructions on the read me file reads as follows. 1. First, copy the files of pcutplot.cfg and pcutplot.eng to the sub folder of CASMAT. Step 2. Open casmat , one click "other{1}" menu, then click "set{s}". Then a dialog box will be opened. Selact the pcutplot on the left of the dialog box(driver file list v), then add it on the right of the dialog box(driver p which is on work), and set it as current apply driver program. The default port is com1. If useing com2 , then you should set the third step, or you can start to work. Problem one is the sub folder casmat does not exsist because pltdraw does not load it on the computer so i created it and copied the two files as per the instructions then came problem no 2 no matter what i do i cannot make the dialog box open. can any one clarify these insruction in plain english and tell me what to do. :banghead:
    Jack Hendrie replied 13 years, 3 months ago 2 Members · 2 Replies
    9 September 2012 at 18:39
    There’s a section on the website for these type of plotters, sorry can’t be any more help than read through that & try a search.
    If you introduce yourself & tell people a little about yourself & what you do you will also find you get far more help from other members.
  • Jack Hendrie
    14 September 2012 at 18:59
    lol i have had experience in cheap ebay cutters i feel your pain brother.
    best thing to do is make sure all drivers are updated
    ur cutting programe is set to the right comport
    all firewalls are off
    this is stuff that i got stuck at. once its going but its ok paid for its self in a few days.
