Home Forums Software Discussions Signlab Software LIYU model is SC631-630
  • LIYU model is SC631-630
    Posted by Tara on 13 August 2010 at 00:58
    Hi, I purchased the above cutter and was assured by the seller that it works with signlab, I have tried this with signlab it does not work, I have also spoken to a man that contacted the manufacture of the cutter who have stated that it does not work with signlab. Can anybody here confirm that it does or does not work with signlab?
    Ray Wilcox replied 15 years, 3 months ago 2 Members · 2 Replies
    13 August 2010 at 06:49
    Tara, why not give cadlink a call?
    they will have the difinitive answer,
  • Ray Wilcox
    27 August 2010 at 13:25
    Hi Tara, I have looked on the net for this plotter and it says it will accept HPGL or DMPL language and run from serial or USB ports. Signlab can output using both of these languages and ports. So it should not be a huge step to get it running form Signlab. Try installing a Roland PNC 1000 driver and a summa d series driver, this covers both languages. Then try selecting the same port as you use in other software and see if it plots.
