Home › Forums › Sign Making Discussions › Off Topic Chat › Litho print advice Off Topic Chat Litho print advice Posted by Gary Davis on 19 November 2004 at 12:06 Hi, can anyone advise if the textured fills/fountain fills in Corel Draw 12 are of a higher enough quality/DPI for litho print? are they just bitmaps? looking at a size of A4 as a flood fill background, dont want it to end up with banding or pixellation! thanks. Gary Davis replied 20 years, 11 months ago 2 Members · 2 Replies 2 Replies Tim Painter Member 19 November 2004 at 12:10 when you use the textured fill select the options menu there you can change dpi 300 should be fine. I have used textured fills in the past for litho No problem. Hope this helps Tim. Gary Davis Member 19 November 2004 at 12:30 cheers tim will give that a try! Log In to Reply Log in to reply. Public All Members My Connections Only Me PublicAll MembersMy ConnectionsOnly Me Public All Members My Connections Only Me Log In to Reply Start of Discussion 0 of 0 replies June 2018 Now
