Home Forums Vinyl Cutter Discussions General Cutter topics linking plotter up
  • linking plotter up
    Posted by Stuart Murrden on 3 March 2008 at 18:08
    hi ive purchased a plotter and linked it with a usb cable and linked it to com2 like was advised by supplier but it still no responding when i output to cut any help much appreciated thanks
    Stuart Murrden replied 17 years, 9 months ago 8 Members · 17 Replies
  • 17 Replies
  • Brian Hays
    3 March 2008 at 18:18
    May help if you let people know what Plotter you have & what Software you are going to drive it with.
  • Stuart Murrden
    3 March 2008 at 18:22
    DG800 runs with artcut software should o just put the money in to a decent purchase but hopefully make money back on this one first.
  • Peter Mindham
    3 March 2008 at 19:26
    Karl is probably the best to deal with this inquiry. I am sure he will be along soon.
    He has a lot of experience in this sort of thing
  • Steve Underhill
    3 March 2008 at 19:30
    Set it to a USB port instead of a com port like you do with a printer.
    That should solve it.
    My GX-24 is set to USB002
    But as mentioned above it may be a mix of plotter and software
  • Frank Droog
    3 March 2008 at 20:26
    A lot of plotters have an FTDI usb chip and software support.
    They show up as a new com port in device manager.
    No guarentee it defaults to com2:
    You can usually change the com port
  • Stuart Murrden
    4 March 2008 at 09:47
    hi ive linked it to various com ports but still no function.Do u fink it could be usb cable?
  • Tim Painter
    4 March 2008 at 10:29
    What ports does you PC have?
    What ports does the cutter have?
    USB is USB & COMM is Serial 2 totally different connectors.
    If your using COMM1 or 2 serial you need to set Baud rate and handshaking and may also need a null modem serial cable.
    Sounds to me that you are using USB but you are selecting Com 1 or 2 as the port which is incorrect.
    If it is USB you need to select USB as the port
  • Stuart Murrden
    4 March 2008 at 12:28
    when i select the text to cut and output it to machine ive tried selecting com ports and usb but it jst says transferring data and doesnt cut.
    5 March 2008 at 10:20
    why not uninstall everything to do with the cutter / software.
    then conect the cutter, via it’s cable, whatever it may be, and simply switch it on, the computer should detect a new piece of hardware, prompt you to put in the software, and automatically assign a usb port to it.
    i’ve not used com ports in years, everything here is connected via usb and usb hubs, all 8 items, the computer just sorts them out!
  • Stuart Murrden
    7 March 2008 at 18:18
    cheers m8 how do assign it to usb port new to this setting up
  • Stuart Murrden
    20 March 2008 at 21:08
    folks any help here much appreicated
  • Karl Williams
    20 March 2008 at 21:15
    What language or Emulation is it set on? DMPL – HPGl – HPGL2?
  • Stuart Murrden
    20 March 2008 at 21:24
    its HPGL m8.advice i got from supplier was link to com2 tryd that no success cheers
  • Karl Williams
    20 March 2008 at 21:27
    Doesn’t matter what port you are using if the language is wrong it won’t communicate.
  • Stuart Murrden
    20 March 2008 at 21:28
    what u mean by that new to it jst setting out
  • Karl Williams
    20 March 2008 at 21:31
    You doing it full time or playing?
    Speak English and tell me your name.
  • Stuart Murrden
    20 March 2008 at 21:33
    work for big company just now but setting up got good expierence in trade thought i treat myself to machine but cnt get it cutting nightmare
