Home Forums Sign Making Discussions General Sign Topics Lining up lettering on vehicles – advice required, please?
  • Lining up lettering on vehicles – advice required, please?
    Posted by Nick Minnery on 12 November 2015 at 11:19
    I know, it’s pretty standard stuff. But, how do you line up lettering on modern vehicles with panels of all angles?
    Usually, I would go with the ‘spirit level’ straight layout- but this can look naff on some newer vans with their fancy lines- so then I would simply ‘eyeball’ it gradually, till I get a natural look.
    I’ve seen some terrible work on plenty of vans/cars on the road, you wonder how they get away with it.
    Hugh Potter replied 10 years, 1 month ago 11 Members · 12 Replies
  • 12 Replies
  • James Boden
    12 November 2015 at 11:33
    I tend to look for a level line on the van and measure up/down from that line. Sometimes that’s not always possible so I use my eye. I can pretty much do it by eye now, it’s the same with anything I guess, the more you do the easier it gets!
  • David Rogers
    12 November 2015 at 13:04
    Prefer to use the Mk I eyeball.
    Measuring rarely works – stick it on (magnets are brilliant) and stand back…adjust to suit.
    Use crease lines / door tops & bottoms / panel recesses as a guide but always take a few steps back to see if it LOOKS right – some of the newer ‘funky’ commercial vans can really throw you off.
  • Simon Worrall
    12 November 2015 at 20:33
    Very good question.
    Nearly always level with the ground.
    There has to be a good reason if not
    Simon.
  • PeteMiller
    13 November 2015 at 09:57
    Always an interesting question – go with the vehicle lines or the ground line. In most cases they are different so there is a decision to be made.
    As other’s its down to what looks best – but that is in the eye of the person looking.
    If there is a big difference I would chat with the customer and get an idea what they want. If they are not bothered then do what you like. At least you have had the conversation should the customer question it but I am pretty sure they won’t.
  • Ewan Chrystal
    14 November 2015 at 20:25
    I find the lines on a Kangoo some of the worst to even look right. I tend to eyeball most of mine
  • Martin Cole
    16 November 2015 at 10:33
    I agree with David R.
    Make sure the vehicle is on a flat surface and do by eye..if it looks right to you when offered up then 99% of the time it is right.
    The Ford Transit Custom below the main panel is a bit of a f……. though, but done a few now and all looked good.
    16 November 2015 at 11:15
    Adding to what others have said start to think about the lines on the van BEFORE you get to the application stage. Often if you know a particular style of van has awkward lines you can make some allowances while designing the layout & avoid some of the problems down the line.
    Other thing as Pete has said is speak to the customer about it. I normally do this at some point before I give the quote, normally when they first enquire & then again when they drop the van off. If the graphics are cut when the van is dropped off I will normally stick a largish bit on with magnets just to show the customer how it will look.
  • Nick Minnery
    16 November 2015 at 16:25
    Thanks for all the replies everyone.
    Also, I find that when you stand back to check how they line up, it is best to stand back a good 6m+, as anything less and you really don’t get the best idea of how it looks.
    Oh, and have you ever fitted graphics, then opened a door and forgot to put your scalpel through the overlapping letters?? Errrr, I haven’t……………just wondered if any of you have done that………… 😳
  • Ewan Chrystal
    16 November 2015 at 16:55
    Noooo, never done that…what kind of dafty would do that :shake:
    16 November 2015 at 19:09
    quote Nick Minnery:
    No left that for the customer to do!! :lol1:
  • Ian Johnston
    17 November 2015 at 07:44
    Or warped over the filler cap, only to get an pissed of customer call you a few days later when he’s going to fill up and can’t !!! :yikes: :lol1:
    17 November 2015 at 12:10
    I one did a part wrap on a front door, an accident repair if I recall, anyway, I some months later – along the lines of the lock being wrapped over, lovely job apparently but they mentioned something about needing a keyhole when the van has a flat battery… who knew! 😳 😳
