Home Forums Sign Making Discussions Neon, LED, Lighting LightBox Advice
  • LightBox Advice
    Posted by Stuart Miller on 8 November 2011 at 10:15
    I have been asked to provide a set of several light boxes for the interior walls of a clothing shop with brand logos.
    What is the best way to do the face?
    Have quotes for the boxes from both Kestrel and Insight.
    This is an example of one of the logos which are all just block colour.
    I am guessing to use a frosted panel with cut vinyl. Transluscent for any colours and standard black (gloss or matt) for the black. Would that be right?
    Another question is if I was providing these with a image that contained a photo or needing a graduated print what are the choices of material to print on. The box suppliers have suggested a thin frosted panel and a clear front panel with a slide inbetween. What would you print the slide on? and could a paper print work?
    Final queestion. Insight provide the boxes without the panels. Where would be a good supplier of the perspex panels?
    cheers Stuart
    Gary Gray replied 14 years, 1 month ago 1 Member · 1 Reply
  • 1 Reply
  • Gary Gray
    10 November 2011 at 16:28
    Robert Horne or Amari are good for the perspex panels and if you require images then you would get the best quality from printing on Duratran material.
