Home Forums Sign Making Discussions General Sign Topics Lightbox Acrylic Advice
  • Lightbox Acrylic Advice
    Posted by Tim Painter on 13 May 2007 at 09:27
    Replacing some lightbox signage + some additional signs.
    The clients wants to keep everything consistent colour wise.
    The background is going to be a solid red. I want to use red acrylic 5mm throughout to keep the consistency
    On the light boxes I assume I still need to use translucent vinyl? or is normal ok ? if it’s coloured acrylic.
    also what are the + / – of flood coating Opal rather than buying Red acrylic? does coloured acrylic cut out a lot of light compared to Opal / Flood coat?
    First ever light box – so prob asking dumb questions.
    Cheers guys n girls 🙂
    Tim.
    Mike Smart replied 18 years, 6 months ago 8 Members · 12 Replies
  • 12 Replies
    13 May 2007 at 09:40
    What colour of text is going on the red background Tim? And is it vinyl text?
    If it’s vinyl text go with an opal background, red translucent vinyl with the text areas cut out and translucent vinyl in whatever colours for your text.
    But someone else will probably have a better answer
  • Gert du Preez
    13 May 2007 at 11:43
    The Red Acrylic/Perspex I get from my supplier is completely opaque, i.e. no light gets through. You can use regular vinyl on Opal 050 Perspex, but it is a bit glossy. The tranlucent vinyls are matt, and looks tons better.
  • Tim Painter
    13 May 2007 at 12:18
    Hi Marcella
    Text is Yellow & White cut vinyl.
    13 May 2007 at 12:52
    oh the chinese one?
    Go for opal 050, red translucent with all text cut out, that leaves the white areas and then infill the yellow areas with yellow translucent. 😀
    that’s what I’d do.
    13 May 2007 at 21:33
    Tim, some coloured acrylics block out a lot of light and some let quite a lot through but regardless of how much light gets through you need to use an opal acrylic. If you use a red acrylic sheet then the yellow won’t be yellow and the white won’t be white because of the red acrylic colour if you see what I mean.
  • Mike Grant
    14 May 2007 at 20:58
    You will only be able to use red acrylic if you jigsaw the lettering out and use coloured acrylic behind, but obviously your question tells me you don’t have that skill so go down the opal and translucent vinyl route. A lot quicker and better looking.
  • Colin Crow
    14 May 2007 at 21:12
    Some acrylic suppliers will supply the red acrylic with the "holes" pre-cut and then supply the exact yellow and white letters to fit perfectly into the holes. Since it’s all cut by CNC there are usually no gaps and if you use a gap filling adhesive like tensol there should be no problems. To give extra support to large cut outs it’s necessary to overlap the rear of the letters with pieces of clear acrylic in a few places.
    All the best illuminated signs are constructed this way as it offers uniform light transmission and longevity since there is no vinyl to fade.
    Colin
  • Tim Painter
    14 May 2007 at 21:37
    Thanks all.
    First light box and I wanted to get the info on what is good practice, as I like to walk away from a job knowing it’s constructed in a way that I can be satisfied with.
    Just like to ask those that have more years in this Trade than I have their advice as I respect the addition knowledge.
    Mike I do have a few skills, wired 20 thousand wires all in pink PTFE as part of a flight simulator for Lucas Aerospace when I was 19 to military specs…….Just sussed which way to hold a screwdriver now…..a few years down the line but I’m there.
    Thanks for all the gen
    Tim.
    Marcella I don’t know what your using but, you’ve got younger since I started this post…
    :lol1: :lol1: :lol1: :lol1: :lol1:
    14 May 2007 at 21:52
    quote Tim Painter:
    what you after Tim??????????? :lol1: :lol1: :lol1: :lol1:
  • Andy Gorman
    14 May 2007 at 22:16
    Ooh, spooky. I’m doing a Chinese at the moment with the same colour scheme. I’ve flooded the opal Perspex with red translucent (with white letters weeded out) then overlaying yellow onto some of it.
    Perhaps they’re traditional Chinese colours or summink.
    14 May 2007 at 22:34
    quote Andy Gorman:
    there you go Tim ……………….. see! that’s the answer right enough! 😉
  • Mike Smart
    27 June 2007 at 13:10
    Hi Tim
    Just read of your dilemma. I have 40 years of practice with red panels, The correct way is to use red acrylic stencil cut it and close the stencil with what ever colour you want the letters to be. Red is the strongest pigment of all colours and will bleed thru all translucent colours that you apply over it. An example is put white acrylic or vinyl over red acrylic and the red will bleed thru result pink letters when you turn the lights on. The letter colour needs to be dense, black navy blue or bottle green mostly stop all light transmission so will work fine.
    If you have the space to layout the sign panel and flood down colours of vinyl over opal acrylic, this will give you true colours, but remember vinyl will only ever shrink so fitting letters in will eventually leave gaps.
    If a lot of colours are involved in the art work consider a full colour print.
    If just big letters say yellow or white. Do it properly and stencil cut it.use acrylic. regards mike
