Home Forums Sign Making Discussions Vinyl Light Box… help please
  • Light Box… help please
    Posted by Gavin Conway on 6 July 2010 at 10:57
    Hi All – I want to make a light box and need to know if the glass / perspex top should be opaque or clear.. also is a fluorescent light good enough?
    I eagerly await some responses… Thanks Gavin
    Gavin Conway replied 15 years, 3 months ago 6 Members · 8 Replies
  • 8 Replies
  • Tim Painter
    6 July 2010 at 11:57
    Opal Acrylic as it diffuses the light.
  • Matty Goodwin
    6 July 2010 at 19:14
    If it was clear you’d see inside it!
    Matt
  • Graeme Harrold
    6 July 2010 at 19:55
    Glass no no no. As Tim says the opal will diffuse the light otherwise you would have more noticeable light areas in front of the tubes. Fluorescent tubes are cheaper to purchase but more expensive for the customer to run. The opposite is true of LED’s…..
  • Gavin Conway
    6 July 2010 at 20:02
    Hi all…. I seem to maybe have called my item by the wrong name…. 😳
    What I mean as a Light Box is for me to use for layering purposes… I don’t do a lot of layering but am slowly building up my workload and want to build one to use.. Maybe this will help on some replies for the correct item!! Cheers gavin
  • Gavin Conway
    10 July 2010 at 22:26
    Dosn’t anyone use a light box that can advise me??
  • Graham . Shand
    11 July 2010 at 07:09
    I use a light box for layering, but the
    other way to do this, by using clear application tape,
  • Derek Heron
    11 July 2010 at 08:38
    hi gavin
    i think hugh potter made one for his workshop
    some fluorescent tubes under the bench with a piece of reinforced glass inset into the top i have a one similar which was a printers viewing box i put a piece of glass on top it has an opal panel underneath so its not too bright ideal for overlaying vinyl
    hope this helps
    derek
  • Gavin Conway
    12 July 2010 at 18:51
    Thanks guys… I made one at the weekend… looks like a coffin with some perspex on top… made it a bit too deep though – realised too late so just put the bulbs a bit higher up.. I had a pile of low energy long life 75watt bulbs and put 6 of them in… looks like a good enough light so will test it sometime. I have some glass frosting aerosol spray so will try a sample of this on some spare perspex to see if I should make the top opaque… ?? !! Just trial and error. About using clear app tape… I do use it but my cutter is not the best quality and on a long sign I need to re-align a bit from the registration marks…
    Till the test then…. thanks again for the advice – Gavin
