Home Forums Sign Making Discussions General Sign Topics LED letters mounted onto stone, advice please?
  • LED letters mounted onto stone, advice please?
    Posted by KevinGaffney on 5 May 2018 at 18:17
    Have a set of Back-lit PVC letters to mount on a stone shopfront. Want best method for disguising wire connecting each letter. Any tips ?
    Vince Francis replied 7 years, 8 months ago 3 Members · 3 Replies
    6 May 2018 at 01:03
    can you not access the rear of the sign from inside the shop above ceiling cavity?
  • KevinGaffney
    6 May 2018 at 13:13
    Sign will consist of four letters mounted between two windows on second floor of a building. Exterior is an old stone wall so only want to feed one cable through wall. Considering fixing letters to lengths of grey channel and hiding cables in the channel. Stone is rough and high enough that channel will be hardly noticeable
  • Vince Francis
    6 May 2018 at 17:42
    I know one of my clients use a clear coated cable for wiring letters to glass. Whilst it may not be ideal, it may help to hide the cable. If you have enough room inside the letters, loop to the next letter hiding the connectors inside
