Home › Forums › Sign Making Discussions › Neon, LED, Lighting › LED identification help
Posted by Mike Grant on 8 April 2013 at 15:14Can anyone point me in the right direction of a supplier of these particular LED’s please.
Thank you.
😀Graeme Harrold replied 12 years, 7 months ago 3 Members · 5 Replies -
Is there any reason why you need a direct replacement and not just similar modules…?
I want to find out the correct power supply for them. so I thought the easyest route was to find the original supplier. I don’t know if any 12v transformer will work as I am electrically challenged! 😳 😉
Mike if you have a multimeter you could try connecting one module to a 12v dc supply.. measure how many milliamps you get over one module.
take this figure and multiple it by the number of modules you are going to use.
then use the following ( Milliamps x volts ) divide by 1000 = Watts
then order a transformer with about 20% more power (watts) than you need.
simples !
quote :take this figure and multiple
sorry I mean multiply 🙂
Most LED’s will operate over a range of voltages, and some LED transformers come with adjustable voltage regulators. What will matter though is the wattage, making sure the transformer is big enough for the load. What you have is about 0.2W per module, so just count and multiply. Get in touch with the likes of Ashby for PSU’s/drivers
