Home Forums Sign Making Discussions General Sign Topics Layering full print over old
  • Layering full print over old
    Posted by Martyn on 9 November 2020 at 06:40
    Hi all, ive always stripped off old graphics before applying new but i have some very large panels, covered in full print. Replace using same panels. I know you should probably use blockout film but how does standard printed polymeric do the job? im guessing you wont see the old print as such maybe a ghosting behind?
    Martyn replied 5 years, 1 month ago 2 Members · 2 Replies
  • Myles Brewer
    9 November 2020 at 10:12
    Hi Martyn,
    So long as the original is sound & it’s not overly long term (Eventually the adhesive on the first job will degrade) you should be fine. Regarding show through I guess it will depend on the opacity of the new vinyl & what the original print is like. i.e. if there are dark colour areas with a sudden transition to light then it’s possible it will show through. Avery currently do a HOP (High opacity) range which are perfect for this sort of application & have clear adhesive rather than the usual grey which means it’s also great for reverse print window graphics.
    Myles
  • Martyn
    9 November 2020 at 13:25
    thanks
