Home Forums Printing Discussions HP Printers Latex users tricks for ink mark removal on vinyl
  • Latex users tricks for ink mark removal on vinyl
    Posted by Dan Osterbery on 20 March 2018 at 10:45
    Hi all,
    does anyone have any tricks or tips for removing cured latex inks? We have printed something 200cm x 200cm and have a couple of small head strikes on a white background. It has been through the curing unit, is there anything we can do to remove the marks or is it a depth breath, chuck it and start again? On our roland machine we can use a little of the solvent cleaning solution and it gets rid of marks etc.
    Thanks in advance
    Dan
    Kevin Busby replied 7 years, 9 months ago 1 Member · 1 Reply
  • 1 Reply
  • Kevin Busby
    20 March 2018 at 11:22
    No help i’m afraid i’ve never found anything apart from scratching it off with a blade, might be ok for a tiny spot but not really on anything big.
    If you happen to spot it before it goes through the curing unit you can open the window to pause the print and wipe away with some isoprol but sods law says you just miss it happening.
