Home Forums Printing Discussions HP Printers Latex printing perforated vinyl help please
  • Latex printing perforated vinyl help please
    Posted by Simon Worrall on 30 November 2022 at 17:53
    Hi all.
    I finally called it on my antiquated roland SP540V and went LATEX! I bought a 335. (Applause!)
    Fabulous printer, loading is a pain in the ass, but Im sure ill get used to it eventually.
    However my biggest issue is printing contravision. It warps really badly with the heat. (using high quality Avery perforated vinyl) and touches the top surface of the heater, ruining the print.
    I have turned down the heat to 107, printed with the take up roller engaged (wasting a meter of material) which stretches it down a bit, and eventually managed to print the small car window job I was doing,
    but looking up inside the heater area, you can see it straining to touch the top surface.
    I have some large contravision windows coming up in December, and I really dont want issues with that.
    Can anybody recommend a brand of perforated vinyl thats designed for latex printing? Or a profile that is reliable?
    Thanx
    Tahir https://signsny.com/ replied 1 month, 2 weeks ago 5 Members · 8 Replies
  • 8 Replies
  • Colin Crabb
    30 November 2022 at 22:42
    Only used Metamark, and have no issues – will check my setting on the 315 or 360 and post here.
    1 December 2022 at 09:17
    I have a bunch of windows being done in it next week, ill check our settings to, mate.
    loading the vinyl will come to you mate. like everything there is just a knack to getting it every time.
    keep in mind you do not have to get it spot-on unless you are tracking long distances.
    7 December 2022 at 13:47
    Simon, I had a quick look at the controvision on our latex.
    We have a couple of profiles loaded for controvision such as Oracal and Image Perfect which run through the machine with no problem. I also see that HP have their own controvision generic profile. so maybe worth trying that one too.
    when I say try it, I just mean a test print. 🙂
    You may already know, but from directly on the printer’s control panel. you can search for profiles and it will auto-log into the HP server and download the required profile or you can install it from your PC into the printer. it’s pretty straightforward. but granted, if you are just getting your head around the machine it can all be a bit of a mind F**k!
  • Leslie Anderson
    8 December 2022 at 12:02
    if i ever struggle for a profile, i just use one of the pre-loaded HP profiles from the list. they have worked fine for me so far.
    • Simon Worrall
      8 December 2022 at 17:48
      Thanks Leslie and Rob.
      I looked through all the HP contravision profiles, and the curing heat on all of them looks to be really high, and the vacuum really low, which seems to be the problem.
      On advice from my supplier, Ive ordered the Promoview, and Ive figured out how to clone a profile, turning down the heat and you can add a delay between each printing pass to make up for it.
      • Simon Worrall
        9 December 2022 at 19:20
        Just to update, I printed 10 meters of promoview perforated vinyl yesterday, it went without any problems.
        1500ms interval, 107 degrees heat, 10 passes.
        Thanks for the suggestions everyone.
  • Leslie Anderson
    5 January 2023 at 19:11
    Glad you got there in the end Simon.
    i was told cheaper materials do not react well with the heat in latex machines. so if it is not working well with a profile, it is better to look for alternatives rather than trying to tinker with the profile. fortunately, i have only ever had an issue with some budget banner i was given for free!
  • Tahir https://signsny.com/
    17 November 2025 at 17:58
    Hello,
    I had a chance to print 2 rolls of Sihl perforated window film.
    I used the following settings.
    Curing Temp: 190
    Vacuum: 22
    The curing area cover stays open
    No take-up roll.
    Signs NYC
