Home Forums Sign Making Discussions CNC Router and Engraving Laser engraving through solvent based varnish
  • Laser engraving through solvent based varnish
    Posted by James Haseldine on 23 August 2013 at 17:16
    Hi all,
    Probably a silly question but can’t seem to find an answer on search engines.
    Can you laser through solvent based varnish without it harming the machine or leaving bad residue on the lens? Aside from it’s flammable so will obviously use the air assist, just wondered if anyone else has done it?
    Thanks in advance.
    James Haseldine replied 12 years, 4 months ago 2 Members · 2 Replies
  • Colin Crow
    24 August 2013 at 08:36
    Doubt this would be a problem with engraving as only a minimal amount of material is removed on each pass. I have engraved plenty of varnished wood without trouble.
    Cutting could be more of a problem and would definitely need air assist.
    Colin
  • James Haseldine
    27 August 2013 at 09:17
    Cheers Colin. Gave it a try and looks good. Makes it so much easier to remove the smoke residue!
