Home › Forums › Sign Making Discussions › General Sign Topics › largest aluminium copmposite sheeting available??
Posted by Shelly & Jim on 16 December 2008 at 10:18Hi,
Does anyone know of a supplier of alu comp bigger than 10′ x 5′? Have checked with Europoint and they don’t supply any larger than this.Thanks,
Jim McManus
Graeme Harrold replied 17 years ago 8 Members · 9 Replies -
Think that’s the biggest you are going to find.
The only alternative is real aluminium sheet, which ASD Metal services do a 3m x 2m and also a 4m x 2m.
Other than that, have you considered a flex face?
Try ThyssenKrupp Materials (uk) Ltd on 01384 563144
Nick.
Hi Jim, I’m pretty sure proper dibond comes in larger sheet sizes but as you will know it will be more expensive, not sure who stocks it though up this way. Have you tried Amari and Cox Plastics?
Thanks guys,
Dave, not sure about flex face. These are to be fitted to the sides of ribbed bodied trucks. Ideally, they wanted them with no joins.
Multipanel is in Exeter, the manufacture it there. However they wont sell direct but via distributors (not amari, europoint or robert horne).
If demand, then they make it to size as i understand, but I think you get that with DiBond too
thanks to all, some good contacts there, will phone around later.
cheers,
Jim
Amari supply a Reynobond sheet in white that is 4 metres long X I think 1.5 metres
Perspex Distribution do the Multipanel sheets at 4m
Macky -
quote Steve Morgan:Amari supply a Reynobond sheet in white that is 4 metres long X I think 1.5 metres
Correct, pain in the ar$e to handle by yourself!!
