Home Forums Software Discussions Adobe Software large sized print
  • large sized print
    Posted by tom seymour on 17 May 2011 at 08:24
    Hello i have an image to print which is larger than my material, i would like to divide the image in half to print in two sections and join when its put onto the van.How do i split the image in illustrator and then put a cut outline around it . The image is a pdf with a vector cut outline.
    many thank Tom.
    Peter Normington replied 14 years, 6 months ago 1 Member · 1 Reply
  • 1 Reply
    17 May 2011 at 09:06
    Hello Tom,
    you might get a better response if you introduce yourself in the say hello section first.
    You should be able to tile the job in your rip though
