Large Logo Installation Advice
Have had a large flat cut aluminum logo fabricated by Applelec. Overall diameter 1200mm. Threaded rods screw into nuts on the rear, 50mm length with a 10mm spacer to give a slight lift from the exterior wall. Have a template for drilling holes correctly. Has another aluminum shape welded to the top of the main shape, so quite weighty.
Just after a couple of pointers really. What adhesive would you recommend to hold the rods in place? Will a 8mm wide hole be suitable to give enough adhesive around the threads?
Thanks for any assitance
Kate
