KCUT 24in Vinyl Cutter plotter new in box on stand
Hi Guys, I bought this just before I got my versacamm, so it hasn’t even been opened and is still sealed in the box. I have all the software link emails etc that where sent through with the cutter..
It’s a KCUT CA24 …. I would like £235 for it please including delivery
here are the details
Feature:
1. Patent stylish streamlined body and top-setting control panel, easy with durable keyboard operate.
2. Adopt new micro-step algorithm to ensure high-quality cutting with high and smoother curves.
3. Software makes cutting precision adjustable for various materials.
4. Improved shock-absorber for quieter working environment while motor power remains the same.
5. Superior aluminum alloy body has lighter with special processed surface can last over 10 yeas.
6. Dual-press sheet and dual cutter position plus half-cutting layering which enable vinyl and paper template cutting.
7. Optional software (Windows 98/NT/2000/XP Compatible ) is compatible with many HPGL software.
8. With plugin for enables easy cutting from CORELDRAW directly.
9. Products are manufactured under ISO9001-2000 standard and pass PRC/CE safety , quality and environment inspection.Item No. KCUT Pro CA24(CA630)
Main Board 16 bit CPU , 8 Mb high-speed CACHE Memory
Control Panel 2X16 character LCD display , 8-keys soft keyboard
Drive Stepping motor and micro-step driver
Acceptable Media Width 730mm
***** Area Width : 630mm Length : 25000mm
***** Speed 500mm /s
***** thickness 1mm
Cutting Force 0 to 500g(digital adjustment)
Mechanical Resolution 0.025mm
Repeatablity Within 0.1mm
Blade Type Sweden SANDWIK professional alloy –steel blade
Offset 0~1mm
Instruction system HPGL / DMPL
Interface RS 232C (standard RS 232 )
Buffer Size 8 Mb
Power Supply AC220 50Hz / AC110V 60Hz
Power Consumption <100VA
Operation Temperature 5 to 40 °C (41 to 104 °F )
Operating humidity 35% to 80% ( non-condensing )
External Dimension 1030mm (W)x 375mm (D)x 380mm (H)
Weight 18kgs
