Home Forums Vinyl Cutter Discussions Mimaki Cutters Jv3 mimaki 160s print problem. Print quality not sharp
  • Jv3 mimaki 160s print problem. Print quality not sharp
    Posted by pete james on 20 February 2014 at 18:59
    Hi guys i have a mimaki jv3 160s, machine was running fine until one day it decides to turn sour 🙁
    Problem 1
    The print seems to have a slight colour edge over the side of the print, which comes now and again.
    Problem 2
    The whole print prints fine but around the edges of print is slighlty off, with yellow and green outline and one side slight pink outline.
    I have peformed numerous test cleans. Plenty of nozzle washes, cleaned capping station, Changed dampers, Changed ribbons.
    No problems with pumps,
    Please help, i hope somebody can help me out there..
    Stafford Cox replied 11 years, 10 months ago 5 Members · 8 Replies
  • 8 Replies
  • David Rogers
    20 February 2014 at 19:04
    Looks like your head carriage has maybe taken a bit of a whack and/or the bi-directional calibration is a bit out.
    You can re-calibrate it through the menus most likely…but if you’ve had a carriage jam / head strike then it may be a manual realignment with the adjusting screws.
    Both take time…and usually require you to accept an ‘it’s close enough’…or call your friendly engineer and empty your pockets.
    20 February 2014 at 23:53
    I had the same machine once…. head strike is correct… one thing tho.. keep an eye on Thick and Thin settings, have u moved them recently? It’s a bit Micky-mouse that control.
    There is hidden engineer menus… need i say more… these help align the print heads…
    but u better of ringing someone who can help
  • pete james
    21 February 2014 at 08:38
    Hi Dave and David thanks for your help, I’m gna give it a shot.
    I think u may be right it had a head crash and may have moved .
    I’ve changed that thick thin many times
    Makes no difference. How do I get into the hidden engineer menu?
  • pete james
    21 February 2014 at 09:27
    hi i went to adjust the head and this problem was there, my mate played around with media comp settings,?????????
  • Jamie Wood
    21 February 2014 at 09:35
    Looks like you need to soak the heads for a bit (!) to clear the blocked nozzles….
  • pete james
    21 February 2014 at 11:04
    the worst has happend are these machines just rubbish or what…
    error head 07
    -*—- thats whats displayed on screen
    any solutions without buying a head 🙁
  • Jamie Wood
    21 February 2014 at 11:31
    Unfortunately, that is likely to be a head. How old is the machine? We’ve had ours for
    nearly 8 years, and it’s still going strong, so definitely not rubbish. They do need
    looking after though….
  • Stafford Cox
    5 March 2014 at 12:00
    Oh dear, that’s really not looking too healthy.
    Head 1 has had a knock (K/M) and has damaged the surface of the head.
    Head 2 has major deflections (C/Y) and will really struggle to print solids.
    Head 3….. where are you light colours!?
    Error 07 is that head 1 right side (M) has an electrical fault. Either the head itself, maybe cable, but could also be slider or mainboard, or combination of any of the above. Did you discharge the printer correctly? Did one of the head cable get moved or removed while there was still power in it?
    I hate to be the bearer of bad news but that is going to need some money spending on it, and it won’t be hundreds I’m afraid.
    Stafford
