JV3 130SPII – New printheads not firing?
Hi All,
I’m a new member here (although been reading through the forum for months now!).
I’ve searched through this and other forums looking for an answer, and to be honest I don’t know if I’m doing anything wrong, but may be missing something obvious?!
I have a Mimaki JV3 130 SPII, two of the heads needed replacing, and as I’m working on a bit of a shoestring I bought an Epson stylus pro 10600 (cheaply!) which has 3 DX4 heads. The printer has had little use, and as it uses waterbased inks thought it would be a good bet to try and reuse the heads.
After removing them, they looked in perfect condition, I flushed them through gently with a syringe and got a good spray pattern from all of them.
I replaced the manifold with ones suitable for solvent ink.For some reason, I don’t get anything out of them whatsoever.
The process I have gone through so far is:
Flushing the heads gently with a syringe
Changing the dampers
Changing the ribbon cables
Pulling about 100ml in total of ink through each head with a syringe (under the capping station)
Changing the capping station
A few strong head cleans
An overnight nozzle wash
Numerous ink fills
Swapping the head with the ones I know are working (the original ones worked in the ‘new’ positions)I’m at my wits end now! Am I missing anything? I haven’t changed the head ID’s but as the original printheads have been moved to other positions and they still work, I’m thinking that this isn’t the problem, and as I understand, the head rank is just to identify the head? (Please correct me on this if this isn’t right).
I’ve tried all three ‘new’ heads and get nothing from any of them, the previous owner of the printer assured me it was working perfectly (couldn’t see any test prints as it was out of ink), they could have been lying, but don’t think so!
Any help or advice would be greatly appreciated!
Thanks in advance,
Sean
