Home Forums Sign Making Discussions Neon, LED, Lighting joining sheets of foamex/perspex or dibond.
  • joining sheets of foamex/perspex or dibond.
    Posted by Aurbab Zafar on 14 October 2010 at 17:11
    hi guys
    i have a 3mm foamex sign im making which is 15ft x 2ft. i have two sheets of 7.5ft x 2ft so they will join in the middle. is there any kind of extrusion/trim/plastic i can use to join up the two halves so they are more secure?
    this particular sign slide into a ‘mini-trim frame’, so how do i ensure the join is secure?
    best regards
    H
    Rafal replied 14 years, 8 months ago 7 Members · 8 Replies
  • 8 Replies
  • Luke s Bremner
    14 October 2010 at 18:54
    Put a panel down the back of the join with d/s tape.
    14 October 2010 at 19:27
    rebate the edges
    and use spring tensioners in the end of the frame
    14 October 2010 at 19:47
    I would have to say you should NOT be using 3mm foamex for this size of sign mate. further more, you should not be using mini-trim either.
    to join it, you could use a strip of any decent rigid flat material using a good bonding double sided tape. this isn’t ideal, but it will be as strong as much the rest of the sign because this is definitely going to fail come winter, if not before.
    sorry to be so negative mate, but would rather point this out to save you headache further down the line.
  • Bob Clarkson
    14 October 2010 at 20:26
    Absolutely Robert, even with a hanging strip it’d be pretty risky, as they say, "one guest of wind" Make sure your public liability is paid up too.
    14 October 2010 at 20:37
    Sorry I mis read thought it was 5mm
    extra 2mm makes a difference
  • Aurbab Zafar
    14 October 2010 at 20:54
    ah drats
    forgot to add, its a temp sign and INDOORS
    the materials should be up to the budget hopefully
    ill try the double-sided tape, but thanks for the suggestions, i think 5mm would be better of course
    14 October 2010 at 21:20
    quote Aurbab Zafar:
    Oh dear………They might be up to the budget – but they’re not up to the job 😕
  • Rafal
    26 January 2011 at 23:33
    I fry up but I’m still just reading You guys !
    So what will the best material print on for that kind of job ? for external use ?
