Home Forums Vinyl Cutter Discussions General Cutter topics jaguar signpal 1320 windows xp ?
  • jaguar signpal 1320 windows xp ?
    Posted by Derek Heron on 29 May 2006 at 08:57
    morming
    decided to upgrade the pc running the 1320 jaguar cutter
    from 98 to xp
    with a new pc so installed the software no problem dongle in
    plugged cutter in but not finding it cutter is fine as i plugged it back into the old pc with the dongle and no problems i have matched the settings but still no joy
    am i missing something
    Nigel Pugh replied 19 years, 7 months ago 4 Members · 11 Replies
  • 11 Replies
    29 May 2006 at 09:14
    Derek What sign programme are you using, and usb or serial?
    peter
  • Derek Heron
    29 May 2006 at 09:34
    Hi peter
    it is a serial connection
    and it is signpal 7.0 master edition
    Derek
    29 May 2006 at 10:19
    Derek I am not aux fait with sign pal,
    So cant help I’m afraid. apart from asking if you have installed the plotter in signpal?
  • Derek Heron
    29 May 2006 at 10:25
    Thanks peter .
    i have installed it and gone through all the set up boxes and matched them up.
    only thing i can think of not being a techi
    when it is plugged in pc would normaly flash up new hardware installed
    but i get no message, the packaging has xp version ticked also.
    Derek
  • Nick Minall
    29 May 2006 at 10:42
    Derek, do you have to tell it the port number anywere?
    Nick
  • Derek Heron
    29 May 2006 at 10:46
    Hi nick
    yes they are both set to comm1?
    would that sound right
    derek
  • Nick Minall
    29 May 2006 at 10:51
    how many comm ports do you have? if more than one just try them all!
  • Nigel Pugh
    30 May 2006 at 10:38
    Hi Derek, do you want to give me a call so we can get you working.
    Nigel
  • Derek Heron
    30 May 2006 at 12:04
    hi nigel will ring later awaiting a call from the supplier
    might just be an update i am still able to cut just re loaded on old pc
    Derek
  • Derek Heron
    5 June 2006 at 20:16
    Just an update my pc s com1 port has died i have just been informed.
    thanks for all the help on this problem guys.
    nigel thanks for talking me through set up etc
    Derek
  • Nigel Pugh
    6 June 2006 at 08:18
    Glad you got the problem solved Derek, and of course glad to help.
    Nigel
