issues with printing to size
I have a very nagging issue with my HP Z2100 A1 printer.
As you can see in the photos, the page size in corel draw X5 (set at 150 x 400mm) safely houses the emblems that are to be reproduced – with plenty of room to spare.
yet when I go to print, set the page size in HP preferences, and ok it, the preview always seems to crop the image.. as seen by the dotted line around the images. clearly the page size is big enough but…
I had to set the printing page size to 150 x 400 to allow the extra space – subsequently wating more material than need be.
How can I cure this? I’m sure when I first got it I would simply have corel on an A1 page size, send a full print to the HP with A1 selected in the preferences and away it would go – no problems..
it doesn’t seem to matter whether it printed direct from X5, a pdf or a bitmap, it always crops it.
wasting a little material is ok in the short term but, it doesn’t help me long term, nor does it help when I have a 594mm wide A1 poster to print, and then have to make it smaller to print it within the A1 boundaries without being cropped.
I have the same issue when printing 600mm wide roll-ups, I end up having to go down to 590 or 585 in order to stop it cropping an edge.
surely the whole point of a printer that takes 610wide media is that is can print the full width A1 or 600 roll up media… I’m sure I must be doing something wrong.. any help appreciated!
thanks in advance.
Hugh
