Home Forums Software Discussions Corel Software is there any way to make repeat numbers in sequence?
  • is there any way to make repeat numbers in sequence?
    Posted by George Elsmore on 14 May 2007 at 08:47
    Morning all, I am going to produce a large amount of small machine labels
    with serial numbers from 000001 to whatever is there any way i can make coreldraw repeat the numbers in sequence or do i have to retype 1000’s of different numbers
    I hope you understand what i mean
    Ta
    G
    Carl Maguire replied 18 years, 7 months ago 9 Members · 14 Replies
  • 14 Replies
  • Andy Gorman
    14 May 2007 at 08:55
    I don’t think Coreldraw has the facility for sequential numbering.
    Have you got any mates with Graphix Advantage? That does it, maybe someone could set it up for you and provide the file.
  • George Elsmore
    14 May 2007 at 09:01
    dont know anyone with said software unfortunatley
  • Nick Minall
    14 May 2007 at 09:40
    I can do that on my Omega software for you George if you like?
    Nick
  • George Elsmore
    14 May 2007 at 09:41
    cheers Nick I will pm you shortly
    14 May 2007 at 10:33
    Just for info,
    as you have it sorted,
    signlab can also to seqential numbering, and even insert different text int badges etc.
  • George Elsmore
    14 May 2007 at 10:38
    Thanks Peter
    14 May 2007 at 12:06
    Corel has mail merge but its linked with the printer side… can be done with programming VBA, so if SL can do it then use that.
  • Peter Shaw
    14 May 2007 at 12:18
    I don’t know what RIP you are using but the latest upgrade to Versaworks included the facility for variable data.
  • George Elsmore
    14 May 2007 at 12:25
    I use colourip does anyone know if i can do it in that?
  • Peter Shaw
    14 May 2007 at 12:35
    Colorip is Wasatch which some people may be using as Troop. When I was using it, it did not have this facility.
  • George Elsmore
    14 May 2007 at 12:41
    Thanks for your time
  • graham stewart
    14 May 2007 at 12:44
    George
    If you use Corel go to http://www.asigns.com and down load SIGN TOOLS3 ,
    you can use it 25 times as a full version, it can do what you wont.
    Any questions E-Mail Andrew he is only to happy to help , sales@asigns.com
    Graham
  • Colin Crow
    14 May 2007 at 13:16
    Haven’t tried this myself as I use signlab but you may find this number generator utility for X3 useful?
    http://www.unleash.com/jeffh/numbering/index.asp
    Colin
  • Carl Maguire
    26 May 2007 at 23:32
    Well I use a roland Versacamm machine which in the versaworks latest update has got a variable data option which u can use from exel what are u using ?
