Home Forums Software Discussions Corel Software Is there a simpler method to use powerclip for cut outline?
  • Is there a simpler method to use powerclip for cut outline?
    Posted by Chris Windebank on 18 January 2008 at 08:54
    Hi, am new to print and cut. I have been playing with the print and cut on the versacamm and wanted some opinion on cut outlines. Most are easy in Corel, using outline or contour but today I had a jpeg and used the Powerclip which simply places what you require of an image straight into the container, then giving it a hairline ready to cut.
    Is this an option anyone else uses? Is there a simpler method you can tell me about?
    TimDouglas replied 17 years, 10 months ago 4 Members · 7 Replies
  • 7 Replies
    18 January 2008 at 15:42
    I have just sent a job to my colleagues for print and cut and I did as you describe ie picture in powerclip with hairline for them to colour as required their end. I’m assuming your rip requires a given colour for cutting part so add that to your pallet so you can right click for easy quick colouering.
    Alan D
  • Chris Windebank
    18 January 2008 at 15:51
    Glad to see I am not the only one using this method, seems quick to do and perfect everytime
    18 January 2008 at 16:24
    Powerclip is something I use all the time, surprisingly many people I speak to are not aware of how good it is and spend ages in Photoshop or similar.
    Alan D
  • TimDouglas
    18 January 2008 at 17:56
    Is it possible to powerclip a vector inside say a word and have it stay as a vector to be able to vinyl cut, every time I do it the powerclip disappears in wire frame ? Is this possible? Corelx3
  • John Wilson
    18 January 2008 at 18:31
  • TimDouglas
    18 January 2008 at 19:20
    That was a good tip, I just saved some time trying to do the print and cut ! I’m hoping that I can place a flag ( vector ) inside numbers ) . Is there an easy way, Using power clip is good for print and cut not cut /cut if you understand.
  • TimDouglas
    18 January 2008 at 19:30
    Forget it , im losing it INTERSECT button 😳
