Home Forums Sign Making Discussions Vinyl is there a garment film that can be printed using the JV3?
  • is there a garment film that can be printed using the JV3?
    Posted by Karl Williams on 13 June 2007 at 23:13
    Does anyone know of a decent quality and not to pricey Garment film that can be printed on using the JV3?
    Kevin Flowers replied 18 years, 5 months ago 8 Members · 9 Replies
  • 9 Replies
    13 June 2007 at 23:43
    i have just done the rounds on this stuff and personally dont like the feel of it at all far to plastic to the touch. graphtyps and targets print well.
    if i was to go full colour shirt printing it would be dye sub the look and feel is far Superior.
  • Karl Williams
    14 June 2007 at 00:55
    Thanks Chris.
    Dye sub is something I know very little about. Wouldn’t mind seeing how it’s done though. I understand you can use a normal printer for this. Is the HP any good? How much are the inks? Thanks.
  • Peter Mindham
    14 June 2007 at 06:16
    Hi Karl
    You can only use Epson printers for Dye Sub. Either a D88 (A4) or I believe now the 1800 (A3) are the best. There is a section on dye sub in the forums, maybe a good place to start? 😉
  • Mathew Parrott
    16 June 2007 at 08:56
    mod-edit
    spamming 🙄
  • Brian Hays
    16 June 2007 at 08:58
    Mathew I think maybe you should read the board rules before you post any more. That is 4 out of 4 posts blatantly plugging somebody that most of us have never heard of.
  • Mathew Parrott
    16 June 2007 at 09:30
    mod-edit
    spamming 🙄
    17 June 2007 at 11:31
    Karl, I posted this before…. cant remember now as we never tried it.
  • Mark Elvidge
    17 June 2007 at 19:38
    the best one i have found is by xpres. apparently washable upto i think 60 degrees and doesnt curl like other material when cut.
    heres the link http://www.xpres.co.uk/consumables/vers … _materials
  • Kevin Flowers
    17 June 2007 at 21:52
    i used the Xpres stuff for the UKSB shirts for Rob at this years SignUK printed with ITL Ecomax inks, but did curl if you cut immediately after printing but Ok if you leave a small white contour.
