Home Forums Sign Making Discussions Vinyl is reflective a dry only applied vinyl?
  • is reflective a dry only applied vinyl?
    Posted by steve geary on 6 July 2005 at 20:23
    So My first question here….
    I recently Did a few ambulances, and it was my first time using Reflective vinyl on a larger scale. (AVERY)
    WoW… this stuff adds time! cutting, weeding, application…
    So Everyone says Dry application only (avery, my supplier, and some others) I had a very hard time doing it dry and got a lot of bubbles, which seemed impossible to get rid of. The only way that worked for me at this point was pretty much one or two letters at a time with clear application tape. Also I layered the reflective on top of Avery 8 year vinyl which was an outline and shadow…. Is layering in this way a good Idea?
    One local sign shop says they install wet with application fluid. ??
    What are your opinions on this? Why would fluid hurt the adhesive… is it different than regular vinyl. What about wet application of cast vinyl?
    I usually apply most everything wet, but I saw a few threads where some of you guys really prefer dry. (for everything.. ?) I’m not really a beginner, but far from an expert…
    I tried reading up on it on 3m and Avery’s site but didn’t find much.
    Thanks in advance…
    J_J_O replied 20 years, 4 months ago 10 Members · 19 Replies
  • 19 Replies
  • Andy Gorman
    6 July 2005 at 21:04
    Layering the reflective onto another material certainly makes the stuff easier to remove in the future. I have also been told that reflective should always be applied dry. However, I have used application fluid with it and not had any problems. I am referring to engineering grade here – don’t ever use a fluid with any of the high conspicuity reflectives (the honeycomb looking stuff) coz it will fall off.
  • John Harding
    6 July 2005 at 21:19
    ive used wet app on flexi lite class 2 reflective, as part of red yellow chevrons on rear of vehicle, ok as long as your not following internal contours then it needs to be done dry.
    fleet been on the road 3 yrs now no probs
    john
    6 July 2005 at 21:23
    Avery should not be applied wet, The edges will start to lift in a few months (been there done that)
  • Johnny Taylor
    6 July 2005 at 21:28
    Hi Steve
    We have been advised to only dry apply reflectives due to them having a layer of aluminium in the vinyl, this stops the vinyl “breathing” allowing the moisture and or air to escape. Most other vinyls will allow air and moisture through. We use a mixture of wet and dry for most applications, depends on the situation. Hope this is of help.
    Cheers Johnny
  • Andy Gorman
    6 July 2005 at 21:29
    I’ve had the corners lift on Avery XR1000 range when applied dry now you come to mention it! Only happened once, I thought it must have been something on the vehicle but maybe the vinyl was at fault.
    6 July 2005 at 21:33
    They did have a problem Andy around nov/dec last year. I applied some dry, as I normally do, and next day it fell off (not joking).
    Suppliers told me that there was an “issue” and I posted on the boards, others had similar problems.
  • steve geary
    6 July 2005 at 21:36
    Thanks all….
    I’ll keep experimenting with dry application..
    For those who have used avery and 3M, Do you prefer one or the other? 3M is slightly higher in price, but would be worth it to me if it aids installation, and or durability.
    So any quick application tips for doing two color lettering Dry, other than using clear tape, and small sections?
    I’ve done three ambualances so far, the customer is happy, and tells me it’ll be about one a week. The first one, i put fifty hours in… I estimated 15 – 20. I covered painted stripes with vinyl and then lettered it. It Definitely was a learning experience.
    I’ll see if i can figure out how to post some pics…
    6 July 2005 at 21:41
    If you want to show us the pics you will have to use the show us your stuff, forum.
    There are quite a few tips on here about layering vinyl
  • steve geary
    6 July 2005 at 21:43
    Thanks for the tip on the pics….
    I’ve been browsing the tips and tricks forum… It’s Awsome! I’m going to be here for a while!
    6 July 2005 at 21:44
    Hi Steve,
    I always prefer 3M to Avery. Much easier to apply with the clear backing, but I like the feel of the tape anyway. Oracals new 751c feels much the same, but with a paper backing.
    Reflective should always be applied dry as, with its inability to let the water out, due to its metal inner layer, it promotes rust on a metal surface it is stuck to.
    All the manuafacturers will void warranty if applied wet.
    Applying the reflective with a soft applicator is probably the easiest way not to get bubbles.
    I’d suggest you try Oracals reflective too. I have less issues with their reflective and bubbles, although I can not tell you why.
    Hope that helps
    Shane
  • steve geary
    6 July 2005 at 21:50
    Great advice from all… I’ll surely use it.
    Thanks…
  • Andy Gorman
    6 July 2005 at 21:59
    I’ll second the felt squeegee method. I think it is the thicker layer of adhesive that can tend to show any discrepencies in your squeegeeing and a softer one helps. Reflective is a bugger to apply, it is tempting to treat it as you would any other vinyl, but you have to take a bit more time and care that’s all. Hot weather doesn’t help. I recently applied a load of reflective outside in the garden and it was a nightmare under the blazing sun.
    If you can ever call our weather blazing! Warmish maybe.
    6 July 2005 at 22:24
    So andy
    what were you applying reflective to in the garden?
    Roses? trees? elves 😀
  • Andy Gorman
    6 July 2005 at 22:28
    An aluminium tray that was too big for my shed….oops I mean workshop. I had 36 x 3m long ally panels to lay up. They were everywhere, at least I kept them off the kitchen table.
    6 July 2005 at 22:34
    our shed oops garage workshop isn’t that big 😀 think we’d have to use the garden as well 😎 I only have a small umbrella
    7 July 2005 at 00:54
    hi steve
    i have emailed you some dry application video links mate. may help you get an idea on how i do it small scale and large.
  • Phil Halling
    7 July 2005 at 07:21
    We fit 90% of the roadside assistance vehicles for (cant say the name – but their vans are orange) and all the reflective parts are 3m and applied dry, never have a problem although a transit front wing can be a bugger to wrap in it.
    What has already been said about reflectives not “breathing” is correct, and with this in mind should never be applied wet.
    Phil
  • steve geary
    7 July 2005 at 17:32
    Thanks again for all the tips…. The advice will be put to good use!
    Robert Thanks for the videos, they were very helpful. It’s pretty much what i pictured, but helps a great deal to actually see it being done.
    I had no problem saving and opening the vids.. they worked great
  • J_J_O
    10 July 2005 at 10:56
    quote Robert Lambie:
    hi steve
    Hey Robert could you share the links also with us, thanks!
    JJ
