Home Forums Vinyl Cutter Discussions Summa Cutters Is it too risky buying a used summa plotter?
  • Is it too risky buying a used summa plotter?
    Posted by Martyn on 5 November 2020 at 16:48
    Hi guys, im in the market for a larger plotter. Been set on buying a new summa but the price is stopping me from pulling the trigger. Although i have the funds, 3.5k on a plotter which isnt going to change the landscape of my business too much just seems…..crazy.
    Theres a used summa come up, actually bigger 1400 rather than the 1200 im looking for and half the price but im guessing twice the risk 🙂
    Whats your experience on a used top brand machine?
    Im guessing the answer is… just luck
    Robert Lambie replied 5 years, 2 months ago 3 Members · 2 Replies
    5 November 2020 at 19:46
    I think you’d be hard pressed to go wrong with a Summa, as long as it’s not too old I guess. Go and have a look, take a few test cuts and some of your own vinyl with you to check it out properly.
    5 November 2020 at 23:11
    Summa is a great make of cutter, as is Graphtec and Roland etc. I have used them all over the years…
    Buying any cutter or printer is like buying a used car. Might look great, but means nothing. its how it has been treated long term and what’s going on under the hood, so to speak.
    At the end of the day, you may get a great cutter at a brilliant price. but that’s pretty much down to luck!
    Personally, I would advise you to buy the best you can afford! Do not scrimp on your cutter if that’s what is bringing in the “bread and butter” jobs on a daily basis.
    I always buy wider than I really need, it means if you have a printer or cutter, you can add it without being limited on contour cutting at 54 or 60 inches wide. It allows you to plot much wider than having join tiles etc
    A common issue overlooked is tracking and easy setup and alignment of vinyl in your machine. more so on used machines because pinch wheels, grit rollers etc become worn etc which has adverse effects on accurate cutting and tracking of long cuts/prints.
    If you are contour cutting prints, make sure you get plenty test print and cuts done to make sure that works properly too. I bought the top of the range Summa cutter with automated takeup real for roll to roll cutting, from Perfect Colours, only for it to go back for a refund after months of complaints due to being faulty and that was brand new! So it’s not just used machines that can have glitches and I don’t just mean Summa, just coincidental my issue was with one.
