Home Forums Printing Discussions Roland Printers is it possible to print A0 size on a 30" printer??
  • is it possible to print A0 size on a 30" printer??
    Posted by Stuart Green on 18 June 2010 at 20:07
    I was wondering if it would be possible to print A0 (33") width on a 30 inch printer??
    I know it sounds a bit of a stupid question here but what i’m trying to get at here is as long as it prints as 30" but the media can enter the machine then it will leave the margins but i get to print on the A0 size if that makes sense.
    so would the 33" media enter the machine of my roland sp300??
    thanks all 🙂
    Kev Cringle replied 15 years, 6 months ago 8 Members · 11 Replies
  • 11 Replies
  • David Rogers
    18 June 2010 at 20:16
    I know that on my 540 that takes 1350mm rolls I can put through about 1470mm wide material.
    Dunno about the 300…but surely you can tell just by loading some 30" and seeing if there’s 3" to spare?
  • Stuart Green
    18 June 2010 at 20:24
    havnt tried it yet but thought would be safe and ask first incased i get a head strike first which i wouldnt want!! 🙂
    thanks david!!
  • Matty Goodwin
    Stuart….As David says, why not try running the media through?
    Matt 😳 😳
  • Stuart Green
    18 June 2010 at 20:59
    Hi matty,
    as i said just wanted to make sure it would be safe and ask first. media may fit but if somehow it gets caught as the head passes by or something.
  • Matty Goodwin
    18 June 2010 at 21:08
    Sorry mate….
    I think our posts were sent at the same time. otherwise I would read you previous reply!
    Hope you work it out…
    Matt
    18 June 2010 at 22:01
    Stuart
    the printer will only print to its max width, regardless of the media size.
    so no you cant print wider than it is designed for.
    Are you still trying to get something for nothing?
    18 June 2010 at 22:17
    according to the paper work
    max media 30 inch
    max print 29 inch
    18 June 2010 at 22:24
    If the border area is white I can see no reason why a vinyl width of 33" couldn’t be fed through the printer? Naturally it will only print up to 29" but if the design has a 2" white border then I can’t see why not .
  • Matty Goodwin
    18 June 2010 at 22:52
    :thumbsup: Phil!
    Just what I was thinking!
  • John Harding
    20 June 2010 at 13:29
    I reckon you can get 32" max in
  • Kev Cringle
    20 June 2010 at 15:51
    Hi all i reckon 32and 3/8 max there are 2 screws on the front plate that stick up a bit that may cause u some problems otherwise it will accept 33 inch in through the rear of the of the printer, hope this helps
