Home Forums Sign Making Discussions Vinyl is it possible to print a hologram onto clear vinyl?
  • is it possible to print a hologram onto clear vinyl?
    Posted by James Martin on 3 October 2007 at 11:54
    Does anyone know if its possible to get a hologram onto clear vinyl so It can be applied to glass?
    Nick Cliffe replied 18 years, 1 month ago 4 Members · 5 Replies
  • Nick Cliffe
    3 October 2007 at 12:24
    Interesting concept James.
    Are you ‘buying in’ the hologram? If so wouldn’t you be able to spec it so it was backed with adhesive so could be stuck direct to the glass?
    Or are you looking at putting other graphics on the vinyl then adding a hologram? Or do you produce your own holograms??
    Questions questions!
    Nick
  • David Rogers
    3 October 2007 at 12:57
    Sort of.
    Did a search & found this:
    http://www.novavisioninc.com/pages/prd_ … ogram.html
    Probably needs a lot of specialised kit!.
    3 October 2007 at 13:04
    What sort of size is it James? You would probably need a bit of advice from who ever is supplying the hologram but you might be able to do it with an optically clear double sided mounting film.
  • James Martin
    3 October 2007 at 15:32
    Tks for the replies.
    The customer just wants something or the back of his car window, so I was thinking just what you would do with an ordinary printed graphic.
    Haven’t had time to do a proper search myself but will post soon as.
  • Nick Cliffe
    3 October 2007 at 15:40
    If that’s all you want, just get hold of some diffraction (some call it holographic) vinyl and print something fun on it. They even make wrapping paper from diffraction stuff these days.
    Nick
