Home Forums Software Discussions Adobe Software is it possible to export illustrator graphics to corel 7?
  • is it possible to export illustrator graphics to corel 7?
    Posted by Peter Coogan on 22 October 2005 at 10:35
    Hi is it possible to export illustrator graphics to corel 7 I have designed a vehicle livery and would like to export to core 7 & then export to signlab 4.95
    pete
    Peter Coogan replied 20 years, 2 months ago 6 Members · 6 Replies
  • Nick Minall
    22 October 2005 at 12:32
    can you not save it as eps or ai and the import it to Corel?
    22 October 2005 at 12:57
    If you have designed it in ai then you can save it as an older version of ai as an eps as has been said and then import straight into signlab, dont use signlab so not sure up to which version of illustrator you can use but if you saved it as version 8 you should be OK.
  • Chris Dowd
    22 October 2005 at 14:30
    From memory (I don’t have Illustrator on this PC) you export as Illustrator Legacy, then can save as on older version from that!
    Chris
  • Marekdlux
    22 October 2005 at 14:58
    quote signsol:
    Chris
    Good memory. That’s how I save as an older version. File-Export-Illistrator Legacy-Select version #.
    -Marek
  • jeffus – Graphtec
    22 October 2005 at 15:51
    I would export as a legacy ai , as a version 3, and import it straight into signlab, corel7 and signlab 4.9 are quite old versions and 3 is the lowest I could see in CS.
    Jeff
  • Peter Coogan
    22 October 2005 at 17:30
    Thanks for the tips I wiil have another go at it
    Pete
