Home Forums Sign Making Discussions Traditional is it possible to coat or paint on to acrylic?
  • is it possible to coat or paint on to acrylic?
    Posted by Reflexing on 28 July 2005 at 20:56
    Just wondering if it is possible to coat or paint acrylic?
    I know it sounds weird but I want to try something out!
    Rodney Gold replied 20 years, 4 months ago 2 Members · 2 Replies
    28 July 2005 at 23:01
    need more info before I can advise….
    love…jill
  • Rodney Gold
    29 July 2005 at 05:20
    Yes , its possible and pretty simple , you can flood coat with screen inks or just spray paint it. You need to clean it first and use an ionizer on it to remove static.(or some other static removal method) Cleaning is BEST accomplished with warm soapy water. Static is a problem with acrylic , it will attract any dust which will mar the paint finish.
    Clear acrylics can be sprayed from behind and the lasered or engraved.
    There is one BIG caveat to all this , sawing , milling , bending , heatforming and lasering put HUGE stress into the acrylic , espcially extruded stuff. Using paints with solvents can lead to problems if any of these have been done prior to painting as the solvents induce stress cracks and or crazing which get worse over time. Same applies to cleaning it , solvent are not recommended.
