Home Forums Vinyl Cutter Discussions PCUT Vinyl Cutters Is it normal to calibrate scaling?
  • Is it normal to calibrate scaling?
    Posted by Viggo Brøndegaard on 15 March 2017 at 14:14
    I have recently got the possibility to use a Foison C24 for some signs on gymnastics equipment. So I have started learning how.
    When looking pictures of Pcut cutters they looks very much like the Foison cutters. Do they come from same factory or do the two brands have some other connection?
    I have got a problem, that the cut out vinyl is about 4,5 % larger than the drawing seen in Flexi Starter. Then I noticed in Foison Manual, that you were able to correct that by changing some scaling parameters, and it was possible for me to get the dimensions just right. Is it normal, that you have to calibrate the scaling on cutters?
    In the Flexi Starter and the Production Manager part, you can also change scaling. Do this change affect the parameters inside the cutter or is it a separate scaling parameter?
    Viggo Brøndegaard replied 8 years, 9 months ago 1 Member · 0 Replies
