Home › Forums › Software Discussions › Corel Software › is graphtec’s cutting master plugin ok with corel X4?
Posted by Alex Pirozek on 28 July 2008 at 20:38Hi all,
I was just wondering if graphtec’s cutting master plugin is OK with corel X4 as i recently upgraded from X3 and now it wont run from the launcher (cut/plot) button. It pops up a message saying "Running coreldraw not found"
Any ideas??Cutting master 2 version is v1.30
Alex.
Alex Pirozek replied 14 years, 6 months ago 7 Members · 13 Replies -
Ok, Just upgraded to cutting master 2 ver 1.40 and now its saying "Can not run corel macro: macro module not found"
Does anyone know if it is compatible with X4 yet as i’ve mailed graphtec but not had a response back yet.
I might be going back to X3 at this rate…Alex.
All sorted,
Problem was the the GMS cut plot macro wouldn’t write to the correct corel folder as the folder was set as read only. A start up in safe mode was needed and then force ownership back to the user on the said folder and then reset full rights back to normal.
Only then the cut plot macro would go in to the folder and work.(-)Al.
Hello Alex i had the same problem when i started using x4 but graphtec brought an x4 plugin and now its works fine
init great when you can answer your own questions 😛
I glad you posted your answers so others can relate to them thanks ..
How are you finding the plugin? On first looking I thought it was pretty good, Chris had his reservations and the more I used it the more frustrated I got with it. Try cutting groups and it is so slow I found the only way to speed it up a bit was to put everything on a non printing layer with a second printing layer and dragging the item I wanted to cut onto that layer at cut time.
Alan D -
I found the plugin to work pretty much ok apart from the odd occassion were i have to reinstall the graphtec drivers and the plug in again to make it work but hey what else would i do with my time.??? :punk:
Im running vista
I downloaded the plug-in, and when I unzipped it, both of my anti-virus programs went nuts. Has anyone else had this happen?
No i havnt heard of that before regarding the plugin but i have had a similar problem when i had 2 anti virus programs try taking one off and see if that helps.At the time i had Norton ans Avg and they didnt mix.
Hope you get it sorted
Happy new year -
Yes it should be as that’s what I’m using at the moment. Make sure its the latest plug in
Cutting master 2 V1.40Alex.
quote Alex Pirozek:All sorted,
Which folder should not be read only?
On the standard install then the GMS folder found here
C:\Program Files\Corel\CorelDRAW Graphics Suite X4\Draw\
