Home Forums Sign Making Discussions Vinyl is glow in the dark reflective suitable for a darkroom sign?
  • is glow in the dark reflective suitable for a darkroom sign?
    Posted by Russell Pavey on 30 August 2006 at 18:51
    I’ve got to do an acrylic sign that stands out very clearly in a darkened environment, that being an aquariumand also has to be detachable.
    Any suggestions on how best to acheive this with no electrics. Glow in the dark vinyl, reflective..?
    At a loss for ideas.
    Russ
    James Duff replied 19 years, 2 months ago 5 Members · 5 Replies
    30 August 2006 at 18:56
    not sure if im following you correctly mate but…
    if its acrylic and has to glow in the dark, they might be after an "edge-lit" sign.
    if its glow in the dark vinyl, i don’t know why they would stipulate perspex as a backing. anyway, glow in the dark vinyl is called photoluminecent vinyl and can be bought from a few sources. we bout a fair bit from europoint display a couple of months ago…
    you can also buy photoluminecent board.
  • Richard Urquhart
    30 August 2006 at 19:00
    just a point if it glow in the dark and its going to be fitted in a dark room it will never charge so will be very dim
    rich
  • Micheal Donnellan
    30 August 2006 at 19:58
    Tritium paint if you could get it, probably you cant get it but it would work.
    if you you do get tell where
    Paint made from this stuff
    http://glowlady.com/Strontium_Aluminate … owder.html
    Why not use batteries, a engraved acrylic with leds and couple of watch batteries would be bright and last a long time and be movable.
  • Brian Little
    30 August 2006 at 21:34
    quote Robert Lambie:
    if its acrylic and has to glow in the dark, they might be after an “edge-lit” sign.
    just out of interest Rob …how long does the glo last ? on that material as i ve always thought it needs a light source now and again to re charge it
  • James Duff
    30 August 2006 at 21:59
