Home Forums Sign Making Discussions Vinyl is applying vinyl on perspex an easy option?
  • is applying vinyl on perspex an easy option?
    Posted by onestopsigns on 24 April 2005 at 11:50
    must be an easier way to apply white vinyl to a sheet of perspex
    1 meter lond 60 cm high
    have placed on the perspex bit by bit smoothing as i go ,ive put vinyl upside down on table top aand perspex on top thensmoothed
    ive done wet
    and ive still bubbles
    any ideas
    Peter Shaw replied 20 years, 8 months ago 2 Members · 2 Replies
  • Rodney Gold
    24 April 2005 at 14:03
    Biggest problem with pex is that its picks up dust etc – gets static real quick. An ioniser is ideal but a wash with warmish soapy water helps just prior to application. The dust and swarf it picks up are generally responsible. You should get no bubbles if applied wet and squeegeed out from the middle to the sides and edges. Apply using the hinge type method from the middle.
  • Peter Shaw
    24 April 2005 at 17:58
    Can I add to Rodney’s comments about static:
    When you remove the backing paper from your vinyl you will generate thousands of volts of static. On low humidity days you can sometimes hear the crackle. Any dust on the bench will leap onto the vinyl. Thus no matter how clean the perspex is you will have dust problems, particularly on white if you are collecting, for example, foamex dust.
    Clean the bench with a damp cloth. Wipe the backing paper and the vinyl face with a damp cloth. If you are applying wet, lay the vinyl on the bench, pull a small strip of backing paper away and then spray. This kills the static. Continue pulling the backing paper back and spraying in sections until removed. Then check for dust before laying the perspex on.
