Home Forums Software Discussions Flexi Sign Software Is anybody running a Creation PCut plotter off Flexisign?
  • Is anybody running a Creation PCut plotter off Flexisign?
    Posted by Martin Manley on 4 June 2006 at 19:28
    Is anybody running a Creation PCut plotter off Flexisign instead of it’s own woeful Artcut software? When I try, Apart from cutting everything in reverse (which I can get around) the plotter knife won’t lift after cutting a letter and leaves the movement lines as cut lines, therefore buggering up the whole job.
    Any suggestions? (:)
    Martin Manley replied 19 years, 6 months ago 3 Members · 3 Replies
  • Garrie
    6 June 2006 at 12:29
    thats weird, have you tried the cutter with Artcut or any other software, does the head lift then? Can you lift the head using the control panel on the cutter?
    I have the settings I use with Flexi and it all cuts fine
  • Glen Mathers
    6 June 2006 at 19:53
    Seems to me that your using the wrong drivers. Have you tried this site for drivers?
    http://www.signsupplystore.com/productc … ubmit.y=12
    hope it helps.
  • Martin Manley
    21 June 2006 at 18:10
    Thanks folks,
    Just back from holiday so haven’t had a chance to try out your ideas yet –
    Martin 🙄
