Home Forums Software Discussions Adobe Software is a graphtec compatible hardware with illustrator?
  • is a graphtec compatible hardware with illustrator?
    Posted by rugnugdo on 5 September 2006 at 13:12
    is it best to use illustrator and somesort of plugin or are there better programs out there
    i know illustrator isdie out you see so dont really want to start learning corel
    cutter will most likely be a grpahtec c3000
    Nicola McIntosh replied 19 years, 3 months ago 6 Members · 7 Replies
  • 7 Replies
  • Martin Grimmer
    5 September 2006 at 13:24
    Think there are plug ins for Illustrator – you could use the search facility to check previous threads. I have Flexisign Pro and Illustrator – if you save Illustrator as version 3, it opens straight into Flexi sign.
    The Flexisign Pro is expensive though – you could try Flexi Letter which is cheaper (Granthams are one of the sellers of this software) which I would assume also opens Illustrator ver 3 files. Think using flexi rather than a plug in would be a good timesaver and money well spent.
    Hope helps.
    Martin
  • John Childs
    5 September 2006 at 13:39
    I can’t agree about Flexi being money well spent. I bought a copy of FlexiCut some years ago and struggled with it for a fortnight before consigning it to the bin.
    If all you want is to cut vinyl from Illustrator I would have though that a plug-in would come in the box with a new Graphtec.
  • MartinDenton
    5 September 2006 at 16:55
    We have Flexisign Pro and we find that for basic design it is much quicker than illustrator, also the production manager – which carries out the plotting is very feature rich and in my opinion well worth the money, it has functions such as the ability to stack jobs, stack jobs by colour, create automatic weed borders, test for sufficient vinyl to plot the job and so forth
    that said perhaps one of the lower levels of flexi, coupled with illustrator might be a good option.
    in terms of familiarity if you are used to illustrator you will find flexi very intuitive with a few more practical functions for sign making than illustrator
    For more complex design layouts and drawing you cant beat illustrator.
  • autosign
    5 September 2006 at 19:23
    quote John Childs:
    I think you’ll find it is rather different now.
  • John Childs
    5 September 2006 at 21:00
    quote autosign:
    It would need to be. It was dire. 😀
    Point taken though. I’ll have another look at it.
  • Alan Wharton
    5 September 2006 at 22:33
    You deffo get a illustrator plug in with the new graphtecs, 2 discs with it the cutter driver and the plug ins for various software.
    5 September 2006 at 22:35
    quote Alan Wharton:
    yep…you do just remembered now also 😀
