Home Forums Sign Making Discussions Vinyl Installing Contra Vision / Perforated Window vinyl
  • Installing Contra Vision / Perforated Window vinyl
    Posted by Pane Talev on 14 September 2017 at 10:16
    Hello forum members.
    How do you install your Contra Vision?
    I’ve done it on few jobs now and when you look strait at it – looks great.
    But, when you look at your finished product from a side you see some kind of irregularity. There is some kind of pattern on the surface of the vinyl? (stretched / melted / 3D kind of pattern)
    • What squeegee do you use?
      Will this disappear in time?
      What can I do to avoid this happening?
      Also, some of the perforated dots are accumulating some air and look like then will blow easy from a jet wash etc.
    (material is laminated with optical clear)
    Please join me in with some comments. Thanks.
    Pane Talev replied 8 years, 2 months ago 3 Members · 6 Replies
  • Iain Pearson
    14 September 2017 at 12:20
    What are you applying the vinyl to ?
    Building or vehicle glass ?
  • Jon Marshall
    14 September 2017 at 13:06
    That weird effect will go after a short while…
  • Pane Talev
    14 September 2017 at 13:15
    Car and Van in both cases.
    I used blue Avery felt squeegee (same I use for car wrapping)
  • Pane Talev
    14 September 2017 at 13:34
    quote Jon Marshall:
    Thanks Jon!
  • Iain Pearson
    15 September 2017 at 10:09
    As Jon says, the marks will disappear.
    Felt squeegee is fine or I use foamex with loop Velcro [emoji6]
  • Pane Talev
    15 September 2017 at 12:43
    quote Iain Pearson:
    Thanks Iain!
